Rear Suspension Bushings and Rear Subframe.
    Originally posted by Ubaderb View Post
    For anyone following along from home and for future reference if someone searches this forum, I did have to add this (https://www.amazon.com/dp/B016W4LHZ4...roduct_details). A mixture of heat, freezing, and some cutting it actually all came out. Still comes out cheaper than the specialty tools but man would it have saved some time for me. Still managed to tweak the RTAB tool.
    you used this to remove the subframe bushings?
      Correct. And I completely forgot that I had to use a hole saw to open up the front bushes a little more since the provided bolt in that kit wouldn't fit.
        Yeah of course man cheapest solution possible is always the way to go.
        And if it looks the same then surely it must be the same those rat bastards.
        they're just cups, if you somehow destroy them, I'd say its user error. Where the problem lies imo is the thrust bearing nut on the amazon kit I bought...I managed to trash that thing on the first slightly off-centered lower balljoint I attacked, technically my fault, so double stacked washers it is...
