Originally posted by Thoglan
Diagnosing a new rear-end "popping" noise
I suppose its possible you had spot weld failures prior to reinforcement? What reinforcement kit did you go with?
I'm currently frustrated as I can't decide which direction to go with fixing this...a fully disassembled vehicle on the quick jack and it's difficult enough to find the time to do the simple repairs I was tackling an hour here and there. Guessing the Vincebar or CMP option is at least a full day or two's effort?
So the popping is caused by RACP separation? Or did you also have loose axle bolts?
My subframe is fully reinforced top and bottom and wheel arch seam welded and I'm sure I have heard this popping every so often.
Great news for me, after this thread I thought I'd do the same inspection on mine after recalling that subtle "pop" sound over my left shoulder last time I drove it...I've got separation on driver side rear arch along the seam, though nothing visible inbound toward the actual rear mounting point with epoxied plates. I dont think I trust my welding skills on that thin edge, all I have is a TIG and it's been a while to jump back in upside down, so I'd really like to find out who you end up using for mobile as I'm in Houston as well.
Side note, that front diff bolt drives me nuts. Mine seems to loosen after every track day and causes a lovely clunk. I finally ordered a Nordlock washer for it to see if that will keep it tight for longer than a couple months...
Plate install was done close to a decade ago, I don't have great documentation of the job unfortunately, though it wouldn't matter much as I only addressed directly at the mount points. There were not an abundance of cracks, just a few noticeable ones on that driver side IIRC. Now, today we realize I should have removed every ounce of coating to inspect, which I obviously did not.
E36 diff bushing that has been on the cover for at least the past 60k miles, still in good shape, not much more deflection than the new set in hand.
I'll accompany it with a photo of the noise that led me to get under there over a decade ago, so my fears were alleviated when I saw that it was just that 100lb diff slamming into the tunnel and not my RACP fully separatedFront bolt issue that presented itself again a few years later...but its still in tact, so we'll give it another go.
Great meeting you yesterday!
First step is to cut out and inspect the top of the front mounts so you can assess the damage. Then clean up the seam sealer around the cracks and a little beyond the cracks you can see.
I know we talked about welding - you will have to MIG weld any cracks. A lot of that welding is upside down which is far more challenging. I would find a mobile welder to do that. Most of the work and cost is the prep work to expose clean metal. You can do most of that as part of inspecting and assessing the damage.
Originally posted by eisen View Post
Urgent probably wasn't the right choice of words on my part, more like "catastrophic". I'm definitely glad I caught it relatively early and am weighing my options for topside reinforcement as we speak. Sorry to hear about your troubles, too, but glad it's all squared away now!
Man, I couldn't agree more. The shops I've talked to about my wheelwell have been shocked and said they've never seen anything like it. This car has had multiple track inspections, too, and I'd hope any M oriented shop would check for common/obvious things like that prior to signing off on it, but I digress. Really, this whole thread showcases that I should've just been more diligent myself 😬.
Originally posted by bmwfnatic View PostYour entire rear left rear mount is pulling away from the car and not held in by much anymore, the next stage is for the panel to start cracking (as mine did), so to prevent further damage (which is much more difficult to repair compared to the stage it is in now, I would say it is somewhat urgent.
Originally posted by bigjae46 View PostI find it amazing how many "BMW specialist shops" that supposedly know all about M cars here in Houston still neglect the top side. One in particular had no clue as to what I was talking about. I guess us forum people aren't so stupid after all.
From personal experience, I also have a previously plated car that was en-route to fail again.
You have basically popped all spot welds that kind of ‘let go’ peacefully, the 3 along the wheel arch and at least one visible near the left spring perch (usually at least one more but hidden by thick seam sealer).
In addition to this damage at the rear, the front of the RACP was also pulling away on my car, with all 8 of the spot welds (4 per side) where the RACP attaches to the rear seat area having let go.
I am not trying to scare anyone but in my opinion based on my findings repairing my own M3, the topside reinforcement is very important.
Originally posted by eisen View PostI'm still in need of topside reinforcement and to stitch weld that crack in the wheelwell, but at least it isn't urgent.​
- Likes 3
Originally posted by eisen View PostTLDR: A couple of the E torx bolts that secure the axle to the diff were loose.
That’s good that you found the issue. I’m always paranoid that I missed a bolt so I usually double check them.
I have a new set of axle bolts if you need them. Send me a PM if you’re interested.
Well guys, I found the source of the noise, and it wasn't the RACP (hallelujah).
I spent most of the day digging through the rear of the car looking for signs of any other cracks. Everything looked fine; I even scraped up some of the sound deadening in the trunk and couldn't find anything that could be causing a noise like that (thanks for making that point about it being in the early stages, sapote , it made me want to look for other evidence).
Finally decided to go back through and retrace my troubleshooting steps just in case. After messing around with the driver's side axle, I remembered reading online about those torx bolts from the axle to the diff coming loose on racecars. Decided to check mine just in case and, what do ya know, a couple were loose - one fingertight. Still wasn't convinced that could do it, but torqued them to spec, noticed that it got rid of a tiny bit of play that was there, lowered the car down, and voila - no more noise. What a rollercoaster. I'm planning to order some new ones, loctite them, and hopefully never deal with this again.
I'm still in need of topside reinforcement and to stitch weld that crack in the wheelwell, but at least it isn't urgent.​Last edited by eisen; 05-27-2023, 04:59 PM.
