I’ve had the e46 for a couple years but never really got to drive it as I was getting bodywork done to it and dealing with body shops. Fun times! I just got it back, and forgot just how bad it handled. While in second gear, if I push it, the car goes all over the place. The car is not that strong for it to not be stable. It’s legit unsafe to drive. If I drive above 50 mph, I constantly have to try and keep the car straight. The car has 182k miles and I am not sure what the history was. When I bought the car I knew a lot of stuff would have to be changed. So far these are the parts I will be refreshing in regards to the suspension:
Subframe Bushings
Sway Bar Bushings
Tie Rod Assembly
Sway Bar Links
Stabilizer Bar Bushings
Control Arm Bushings (Front and Rear)
Control Arm Assembly
Trailing Arm Ball Joint
Coil Over Kit
Steering Coupling Assembly (Not suspension related, but still changing)
Subframe will be reinforced as well with Vince plates and bar
Is there anything else I should be considering before I attack this project? I have other stuff that I will be doing as well, not related to the suspension:
Differential Mounts
Engine Mounts
Transmission Mounts
Exhaust Hangers
Driveshaft Guibo
Rod bearings
VANOS
Anything else I am missing, please add. Thanks in advance.
Subframe Bushings
Sway Bar Bushings
Tie Rod Assembly
Sway Bar Links
Coil Over Kit
Differential Mounts
Engine Mounts
Transmission Mounts
Exhaust Hangers
Driveshaft Guibo
Rod bearings
VANOS
