Motorsport Thermostat
    Originally posted by samthejam View Post
    Yes it takes longer without a doubt to get up to temp. The advantage I have found with the lower temp thermostat is in decel zones like 10a-10b at road atlanta, you can get get quite a bit of heat out of the motor, since the thermostat closes later.
    If my car were only a street car it would really not have an advantage. In day to day use I have to consider the longer warm up times, it isn't ideal but is what it is.
    It is going to get swapped out as it is taking longer for the oil to get up to temp according to the gauge.
    I wonder if the oil temp data only comes from the oil level sensor or if it is calculated using other temp data? I remember an old post where someone said that it was calculated using the oil sensor and the ambient air sensor. One of the DME experts might know.
      For those of you running Anri's 70 or 75 thermostat, does it take longer for the oil to get up to temp?​
      Slidewways,
      FYI there is a difference between 70C and 75C.
      Let me sent you a 75C. Try it drive it for a month collect data,
      observe compare to OEM.
      If you don't like it ship it back to me, put the 80C-OEM. If do like
      it buy mine.
      Sent me PM with your address and name and I will mail it to you.
      Were you located in California ?
      S65-B40 79C
      S38-B38 79C
      S38-B36 79C
      S62-B50 79C
      Regards,
      Anri
      www.euroclassicmotors.com
        To clarify for anyone following this thread - Anri installed a 70°C thermostat on my car, which is meaningfully different from the 55°C motorsport unit that opened this discussion.
        My reasoning to go with this thermostat during my cooling system refresh was simple: warm oil, cooler water. On a 20+ year old engine with an original head gasket, I'd rather run a modest buffer below the stock 80°C opening point than have none. That's not a cooling system fix - it's a margin decision on an aging car where I know what the highest-risk component is.
        In practice: oil comes up to temp normally, coolant sits slightly left of center on the gauge - somewhere between the middle mark and the adjacent dot on the cold side. I'm satisfied with that. ChapterM3 has reported similar results even in LA summer traffic.
        I'll acknowledge samthejam's point - longer warm-up times are a valid call out, and if this were purely a street commuter I'd weigh it differently. The ECU/fueling concern is also worth noting for anyone considering the 55°C motorsport unit specifically; at 70°C it's far less of a factor given how much closer that sits to stock.
        The stock 80°C thermostat is a perfectly good answer for most people. For my specific car, at this age, this was the right call. To each their own.
        📸 @alpinem3
          I have 1 OEM Motorsport Thermostat for sale if anyone is interested.. Brand new $70 + shipping
            Has anyone reused cooling system o-rings, mainly the large o-ring for the thermostat and the o-rings on the thermostat housing pipe? I recently replaced these and now need to take it apart again to do a quick swap with a good working thermostat I kept as a spare. I always replace o-rings, but wanted to check if they can be reused if there are fairly new with no tears or deformation. Maybe someone has done this on their track car?
              I would replace to avoid leaks
                If you are in a hurry you can borrow my o ring set and payback later
                  I'm curious what the fuel maps are doing at these different temps. I would generally think of cooler water temps as a good thing all else being equal. But given that there's a relationship between water temps, oil temps, and fuel maps, there can be unintended consequences as mentioned. Longer warmup times aren't good either, especially with our molasses oil. If I could run 180 water temps instead of 210 water temps and not have any change to fuel maps, oil flow rates, etc then I would. But it doesn't really work like that.
                    My thermostat decided to get stuck open the other day and I'm not going to rush to replace it if it is going to act like the 70/75 thermostats. Coolant temp reads 70ish at idle, can drop to 66 when cruising on the highway and only maxes out at 75.
                    This Wahler thermostat has about 6 years and about 20k miles on it. Aren't thermostats supposed to last longer than this?​
                    Just wanted to update this. My issue turned out to be the engine temp sensor under the intake manifold. Lasted 7 years and ~20k miles.
                    I had a spare sensor, so I swapped that in and temp is reading normal now. Luckily, I did not jump to replacing the thermostat. I'd say replace this sensor first if you have the following symptoms: coolant temp needle fluctuates on the cold side above the blue box and first dot, and OBC temp reads 55-75C with no error codes present on the DME. At a minimum, I was expecting an implausibility code, but apparently, the DME logic says that the engine temp never getting to 80C and always reading 55C is perfectly ok.
                      Thats great. What is the part number for the sensor? I think i might have changed mine already.
