Any way to tighten rear view mirror
    Just had my windshield replaced and it seems like the review mirror is more shaky than usually. Any way to tighten it?
    I have a 2006 Coupe
    what part is more "shaky"? the base cover plate or the mirror/mount itself? I'd remove the cover plate, rotate the whole assembly clockwise to ensure it's locked it it's bracket, and install the cover plate properly. should be pretty quick work to understand what the issue is. GL
      If the ball and socket is loose, not much you can do.
      If the part where it sticks onto the windshield is loose, you can take it apart and bend the little wires until they're straight again, then reinstall. They get deformed and loosen up. Pretty easy fix.
