Ok I'm at my wits end here. Last year I bulletproofed the VANOS (pretty much ALL the VANOS and timing assembly parts and upgrades as recommended) on my 2006 M3, did it all according to spec and hooray! Worked great. After about 1000kms, I got an error 184 engine light, checked INPA (Exhaust timing control etc, EVanos1 Control 0000B8 on Carly). The timing was set perfectly when I rebuilt but nevertheless pulled it apart, and saw exhaust cam was slightly out. I pulled off Vanos, adjusted cam with BMW tool, did everything exactly as Beisan, videos, everyone says and it all came together perfectly, even replaced exhaust cam position sensor, seals and gaskets, got a Beisan refurb Solenoid (did previously myself), and replaced elec connector and all should be great... or so I thought!
Same error same thing. Car seems to idle and run just fine (yes I know the error is causing some top end losses that are tough to feel on the butt dyno) but every 2nd run after clearing the error (sits in shadow memory, throws CEL on 2nd occurrence it seems), it just comes back. SERIOUSLY. What could be going on? Please help!!
