Could someone confirm if these rear sway bar bushings are compatible?
    Years ago I purchased from Turner the front & rear sway bar set for my 2001 M3 which I think was still manufactured by H&R. The rear bushings are shot so when I went online for replacement bushings it gives me 2 options, one under the name Turner which is back ordered till October and another under H&R which ships from manufacturer within a few days.
    Would anyone be able to confirm if the H&R variant would fit with no issues?
    Yes, exact same bars, though it doesn't matter - both bushings being same OE shape/design, and the right ID of 25mm means you're good.
      Thanks! I appreciate it man.
        I do think the other difference was on my H&R bushing was Teflon lined while the Turner ones were just rubber.
