DMTL Error Code: B0/51 - Abort tank-leak diagnosis due to moisture
    Hello,
    So i have been getting a DTML Error code that comes up about every month or so. Smog check is coming up in October so i need to fix this so i can pass emissions.
    • Initial Error was in March 2023
      • I cleared code and carried on (maybe a fluke)
    • Error popped up again around around April 2023
      • - Initial research led me to replace the gas cap I purchased and replaced it around May 2023
    • Error popped up again in June 2023
      • Cleared code and ignored it again
    • Error now came up again July 2023
    I decided to look at gas cap again, I did not really clean around sealing surface as there is some gunk build up around metal sealing surface, so cleaned that up. Also noticed a bit of fuel smell and some wetness around the seal of gas cap, definitely smelled like fuel.
    I saw a video on testing the DTML but it was only done in ISTA+, Is this a test i can do with INPA? I tried installing ISTA+ but couldn't get it work. Ill attempt to install it again if i need it to diagnose
    PA Soft:
    - B0/51 - Abort tank-leak diagnosis due to moisture
    ODB Fusion Scanner
    - P1434
    INPA:
    176 interner Index 174
    Error frequency : 1
    Logistic counter: 40
    Motordrehzahl 3000.00 1/min
    relative Fuellung 39.20 %
    Kuehlwassertemp. 1.00 Grad C
    Lambda-Adaptionsoffset 1 0.77 ms
    aufgetreten vor (rel. BZ) 3.70 h
    0001 - Kurzschluss UBatt o. Wert zu gross
    Fehler abgasrelevant OBD
    Fehler momentan vorhanden
    statischer Fehler
