THE M3 IS GETTING THE ANRI BUILD TREATMENT - Blown headgasket to build thread
  • cobra
    Sure but does it mean there isn't better solution ? Solution that will
    not get into the valve cover when the silicone is pushed inside and
    cuts off and floats in the oil...and next time you do rod bearings
    you find small tear drop size silicone in your oil pump screen
    yummy...seen it all the time and the reason I never use silicone.
    Nothing better than compound, well I guess we all have different
    methods.
    Regards
    Anri
    The key is to not use too much. If you have big globs of sealant breaking off inside the engine you have used way too much.
    Almost all manufacturers use it to seal engines and transmissions these days. It is not uncommon to find all sorts of silicone chunks and metal shavings during a first oil change.
  • George Hill
    I am wandering why people still use silicone around the engine ?
    What do you suggest?
    At the dealership we always used Hylomar, but IDK if they have changed the formula or something but lately it seems to not last as long as it did and starts allowing seepage.
    Ultra gray has been my go to and it doesn't leak at all, but the clean up is terrible. *And yes a little goes a long ways, lots of people waaaaay over use it.
  • Anri
    It is common practice to use silicone at head seams (vanos) and half moon corners since the gasket doesn't always conform perfectly.
    At the water pump, sensors, tubes, etc. it has no place.
    methods.
    Regards
    Anri
  • cobra
  • Anri
    Because it is in the TIS instructions to use Drei Bond 1209 silicone sealant in those areas you have pictured.
    Slideways,
    Do you make a difference between the Drei Bond and RTV silicone
    used in the pic as everybody using ?
  • Slideways
  • Anri
    Gents,
    around the engine ?
    I have seen silicone on water pumps, cams
    sensors, water pump tube etc..
    In my shop I don't have silicone. I use only
    compounds and guarantee no leaks!
    Head is on, moving forward.
    Regards,
    Anri
  • Anri
    I can't see the old groove mark by the oil seal on this pic; did you do any polishing or only cleaning? I'm surprised that the oil Teflon seal didn't cause any wear on the meatal sealing surface.
    Sapote,
    Thanks for your replies.
    This is cleaned surface already.
    Bellow is how they look like before I clean them up
  • George Hill
    With a risk of having people jump into an argument I must say that it's not a problem at all as long as the rocker arm is in a good condition.
    I've done it before too, I laid out all my concerns and the customer wanted to roll with it... It is still running but certainly made me nervous.
  • sapote
    The crank snout was cleaned as well from the old
    grove.
  • sapote
    What do you do to counteract the potential failure from mixing and matching follower on cam lobes?
    I'm learning here.
    But I think if the cam lobe and the new used follower are polished then they should be paired safely.
  • Anri
    Hill,
    rocker arm is in a good condition. I have done it many
    times. On every S54 I rebuild I do polish the rocker arms
    before I install them back.
    Regards
    Anri
  • George Hill
    Originally posted by ChapterM3 View Post
    That's the thing - in my ownership I've never had anyone touch the rockers - so what's worse, a shop forgetting to replace them? or shops not catching they were missing in the past 5 years of my ownership? 🤦‍♂️
    They are in the very back of the head, while I agree it SEEMS like this should have been caught I think its unreasonable to expect a shop to do so without being in the affected area and a valve adjustment isn't "being in the area" IMO.​
    One of the rocker arm has odd damage and was replaced with a good one I have in stock.
  • Anri
    The chain cover was cleaned to like new
    condition.
    grove.
    New seal was installed and pushed in deeper so that
    on the next crankshaft seal replacement the seal can
    will be installed 1.5mm less that means the grove will
    remain after the seal not before the lip of the seal!
    New Chain, all new guides are already in.
    Head is ready to be installed.
    Regards
    Anri
  • Anri
    Moving forward
