THE M3 IS GETTING THE ANRI BUILD TREATMENT - Blown headgasket to build thread
Thanks for adding such good content, Anri. I love following these threads and learning along the way.
We are lucky to have a guy like Anri here on the forum willing to share his knowledge and document everything so well!
Based on what you're saying - a big contributor to the headgasket wearing out would be the number of heat cycles and the temperature range. So - a daily driven car in a cold environment will see more relative movement and higher number of cycles than one used in a more mild environment or for longer trips?
I'm always blown away by how close the cylinders are on this engine. Amazing that it even works in the first place.
- Likes 4
Cobra,Originally posted by cobra View PostLuckily this seems like a pretty easy fix. Clean it up, new head gasket, good to go?
Do you use any sort of copper sealant or special process on the new gasket, or install it as it comes?
Your question has very tall answer.
The genuine Original head gasket has coating
around the important areas, coolant passages,
oil return, bore.
S54 multi layer gasket design relays heavily on that coating.
Cast iron block with the combination of aluminum head it
never works right in thermal expansion when the engine
warms up from stone cold! never ever. Aluminum on Aluminum
works much better (don't get depressed for the beloved S54
there is a solution!)
The massive temperature changes throughout the life
span with the combination of running hot makes the cases
move a lot resulting the coating to shred! when the coating
shreds around the oil return, water passages, the liquids leak
thru immediately regardless of the stamp/design to work as a spring
during contractions around the critical areas.
S54 carried the oil return galleys design from M20 on the
exhaust side. On most S54s the exhaust side is sweat. (At
present I have 3 S62s and all 3 the gasket sweats in
that area) Also the head bolts are too far away from the area
and the support is weaker and when the parts warp little its
over...oil starts to leak from there combined with shredded
coating.
Note in the picture Jonathans head gasket was leaking from
1 all the way to 6 on the exhaust side. Look at the head gasket
coating is shredded and no longer supporting sealing conditions.
One may think that this is left over from previous leaking valve cover
gasket but its not..
The copper spray after few heat cycles do turn into a rock solid
layer. it does work well with other gaskets.
Spraying Copper on the S54 gasket you are basically destroying
the function of the coating.
Please understand I am not saying the copper spray it will not work
but understanding the design of the parts and how it works I do not
use copper spray on factory design gasket. On other brand gaskets
is the only way to seal is via Cooper spray but again not on S54 design
Enjoy the pics.
Regards,
Anri
- Likes 7
Well, there we have it. I want to give a shout-out to the previous owners for clearly taking care of the head gasket and apparent coolant in the cylinder which I never knew about or experienced before. Thank goodness I stopped driving it in time to not cause more damage, wow, this is incredible. Thank you for the update Anri looking forward to more as more unfolds - I read your posts like 5 times to make sure I got it all correct haha, thank goodness the block is OK! 🙌
Head is off.
As expected the head gasket failure is between 5 and 6.
Frankly Jonathan did not put many miles from the time
when the engine started to misfire.
Some of you remember on https://nam3forum.com/forums/forum/m...om-parting-out
had massive damage and had to deck the block around ~0.6mm...
In this instance the block has zero damage/s and it does not
require decking. The condition of the head gasket is very tired.
At some point coolant had gone inside. One can see the
small immediate corrosion on the cyl wall but it is noting to worry
because it will clean up.
The deck surface is nasty and required hours of cleaning. I have my own
custom blocks made to only clean the surface from the old gasket and some
mild surface corrosion.This is not taking any material away, don't worry.
It also glazes the surface in order to work with the multi layer gasket Ra.
The bore measured absolute perfect at 86.978mm on the trust side and
87mm on the none trust side.
Regards,
Anri
- Likes 5
OH got it. Yes this was bought and installed in 2020 so that would make sense then. Damn.
My guess is Dr. VANOS was getting them from an old M3F forum member - TurboToy. TT used to buy broken stock hubs and make the modified hubs from those. TT stopped buying the hubs at one point and it looks like they are discontinued now. As the stock or Beisan hub + redrilled disc became the go-to solution, the modified hubs were phased out.Originally posted by ChapterM3 View Post
Wait, are you saying that I have a TurboToy Hub installed? I've never heard of that hub
Here were the parts that were ordered from Dr. Vanos and installed on my car -
- Dr. Vanos D300 Exhaust hub - This was ordered directly from Dr.Vanos but it's not on their website anymore, this is the one that was ordered: https://www.moreheadspeedworks.com/p...0_exhaust_hub/
- S54 Cam Bolt Kit - https://drvanos.com/collections/s54-...4-cam-bolt-kit
- S54 Noise Reduction kit - https://drvanos.com/collections/s54-...-reduction-kit
- S54 Modified intake gear - https://drvanos.com/collections/s54-...ed-intake-gear
Wait, are you saying that I have a TurboToy Hub installed? I've never heard of that hubOriginally posted by Slideways View Post
Not sure what's going on there. This is the Dr. VANOS hub which is $700-800 - https://drvanos.com/products/s54-cryo-exhaust-hub. That TurboToy hub was such a questionable design from day one https://www.bimmerforums.com/forum/s...M3Forum-com%29. A stock exhaust hub + redrilled disc is more than enough.
I'm more curious about the headgasket issue and whether it damaged the block or head since it got to the misfire stage.
First time seeing that TurboToy failure thread. Quite the failure mode. I see that the original post is from 2013. Didn't the company come out with multiple iterations of the design? IIRC, there were at least 3.Originally posted by Slideways View Post
I ended up installing a stock exhaust hub and Besian redrilled disc back in 2013. No issues over 10 years later.Last edited by bimmerfan08; 01-06-2024, 08:55 AM.
Not sure what's going on there. This is the Dr. VANOS hub which is $700-800 - https://drvanos.com/products/s54-cryo-exhaust-hub. That TurboToy hub was such a questionable design from day one https://www.bimmerforums.com/forum/s...M3Forum-com%29. A stock exhaust hub + redrilled disc is more than enough.Originally posted by ChapterM3 View PostAnri - Thank you for the update - Just to mention it the Vanos replacement work was done by a friend of mine and this is the parts list that he got from Dr. Vanos and what occurred during that service:- Dr. Vanos Exhaust hub
- Anti-Rattle Gears
- Cam bolt Kit
- Cam Sprockets
- New Chain Guides
- Checked All Valve Clearances (3 needed one size up) - valves shimmed
- Timing Chain Guide
- VVT Housing Seal
- Oil Pump relief valve​
I'm more curious about the headgasket issue and whether it damaged the block or head since it got to the misfire stage.Last edited by Slideways; 01-05-2024, 07:09 PM.
I hear you. Sapote the idea is not to "Patch" the problem by making the drive pinsOriginally posted by sapote View PostI don't like like the 90* sharp corners on the the OEM hub with the machined tabs, which is a source for stress riser leading to cracking; they should be chamfered at these corner (the crank shaft has the chamfered corners at every con-rod throws for the same reason -- prevents the cracking). Obviously it's cheaper to make parts with no chamfered corners and BMW opted for this way
solid and full round to increase the strength. This hub with its given slack it still
rattles from the lumpy cam operation personal I am not fan of.
The original design is good enough. I was making a point the Beisan is tigher
than the one on Johnathan's car. (I will measure it tomorrow and compare them)
and I was also making a point that the Beisan can go little tighter, I even thought
of making my own custom reamer to spec them to my own.
It does not have too much play, but I am saying it can go little tighter and that is my opinion.Originally posted by sapote View PostI didn't know that Beisan disk new holes are still having too much plays
The pins are not TIG welded. I will take picture tomorrow for you.Originally posted by sapote View PostTig weld the pins for the reason
Regards,
AnriLast edited by Anri; 01-06-2024, 09:47 AM.
- Anti-Rattle Gears
- Cam bolt Kit
- Cam Sprockets
- New Chain Guides
- VVT Housing Seal
Anri,Originally posted by Anri View Post
1. By what 1%...the slack is absolute unacceptable in my book. I even think that the Beisan can be
little tighter, but okay its fine as is.
2.Do you want your hub to see glowing red melted material in the
helical gears drive area ?
Regards
Anri
I don't like like the 90* sharp corners on the the OEM hub with the machined tabs, which is a source for stress riser leading to cracking; they should be chamfered at these corner (the crank shaft has the chamfered corners at every con-rod throws for the same reason -- prevents the cracking). Obviously it's cheaper to make parts with no chamfered corners and BMW opted for this way.
1. I didn't know that Beisan disk new holes are still having too much plays -- how much is the plays if you have the data? 0.004"? When I had my disk drilled, it was about 0.002" plays and I have to be very careful when bolting down the vanos to the head to make sure the hub pins and the disk are not binding due to lack of perfect concentricity by tolerance stacked up from camshaft to pump disk.
2. Of course we don't want to have distorted splines hub from hot welding, but I just wanted to point out that whoever chose to Tig weld the pins for the reason of stress risers by the 90* corner if they were machined. Maybe the splines are with more clearance and so they are not binding up after the Tig welding process and this can be easily verified with the parts in hand.Last edited by sapote; 01-05-2024, 02:05 PM.
By what 1%...the slack is absolute unacceptable in my book. I even think that the Beisan can beOriginally posted by sapote View Post
I thought the driving pins on these non-OEM hubs are larger than the stock hub pins to minimize the plays
Sapote, when you weld particular spot you have stressed the surroundedOriginally posted by sapote View PostMaybe the Tig weld is to prevent the stress-riser at the sharp 90* angle at the base of the pins compared to machined hub?
area and that is never good when you have such a precise design.
It has nothing to do with the sharp 90 as you point. As long as the
parts are tight not hammering it back and forth as on the oem its all
good.
Regards
Anri
