Gents,
Thought of sharing what I am rebuilding currently for a customer.
(I am almost sure he is a member here)
The history of this S54 is unknown. Purchased from a junk yard "as is"
Before the engine was going get installed I decided to do a leak down test and
get information on the health/condition. Started at cyl#1 and ones I push
air I heard the air crossing the block deck to cyl#2 and that was the
beginning...
When removed the cyl head the gasket was burned at the typical place
on 4 cylinders. Now the big trouble is that the heat combined with flames were
crossing back and forth and it torched the block surface and it led to surface
pitting/damage.
Before I proceed further up with this engine the first thing I wanted to find out is
if the block can be cleaned in reasonable measurement.
I set the cutter directly at 0.005"/0.12mm as my first cut, after 1 pass it did clean
a bit but far away from disappearing... then another 5 and another 5 and
one few....so I ended with 0.021"/0.53mm.
The last 2 cuts the blade speed was extremely slow in order to get the surface
as smooth as possible to work with multi layer gasket. At 0.53mm the factory
reference stamp "0" on the block ear is long gone..
Now the deck heigh is 0.53mm shorter, this means the timing chain will change
its length but no by much (its not a big deal since the sprockets are slotted), the
pistons will show 0.53mm more above deck height etc..in single word, trouble.
Cylinder 2 the piston went thru hard detonation resulting broken ring land.
Here is a video with the head removed and the gasket damage can be seen.
https://www.instagram.com/p/Cqws_XPgrp7/
Regards,
Anri.
beginning...
pitting/damage.
Regards,
Anri.
