Saving a S54 From Parting Out.
    What about slightly thicker head gaskets for blocks that need extra mm removed? That combined with ARP head studs should make a block or head serviceable.
    Sideways,
    Thanks for your reply. We will get to that stage as well.
    Regards,
    Anri
    www.euroclassicmotors.com
      You can definitely do that. I ordered a cometic as I thought I’d need it, but only cut .01” from mine total between the head and the block. So that slightly bumped compression to 11.7. Kept it in that state.
      for anything more Cometic makes a ton of gaskets.
        I know very well line2line. It is pretty good stuff and no harm at all.
        I work a lot on S38 engines as well this and have seen those with nearly 300k miles
        and beaten to death with poor oil etc..and the Pistons to wall clearance stays
        pretty much the same....it reaches max permissible and freezes there and that
        is it...I also have seen S54s with over 220k miles and the bores look totally in spec
        just as this one.
        I will post my coating when the time comes around.
        Regards,
        Anri
        love it. Thanks!
          The final stage of the block work is cleaning before assembly begins.
          It's either the machine shop Hot/Tank/BigWasher or my myself.
          I chose by myself because the shops tank/s are filthy dirty...The other
          negative side is the freshly loved bores and deck are getting light
          rust...I am tired of chasing a machine shop who changes
          the solution often and cleans their tanks very often and even then
          to be free of metal shaving, sand, gunk and other nasty stuff......
          I am done.
          The worked out area Bores+Deck these open cast iron metal rust
          so fast that by the time one is done washing the rust stains the surface.
          So the "Trick" I use is I apply heavy duty grease on the bores
          and the open deck. By doing this I can leave the block in tap water
          overnight and nothing will ever happen to the bores nor the deck...
          I will be worried about the block rusting from outside LOL..
          The block is placed down so that all the metal particles come out
          from decking the block. I have various sizes brushes which I use
          to scrub the block oil pump channel/s, the return oil drain channels
          etc...
          Attention to detail: The last stop and very very important is to clean
          the main block Oil-Galley !!!!!
          S54 is an engine from the Era of Fast-Assembly line...so the oil galley have
          been closed via 12.5mm pressed fit plugs. Either decking the block
          or not it's a mandatory of mine to clean the Main Block oil galley.
          Now, BMW sells replacement plugs, but...after so many heat cycles
          will the new plugs sit properly ? Out of the 4 plugs only 1 is inside the
          engine and let say it does sweat a little then the oil will go back in
          the oil pan. But what about the other 3 plugs ? 1 sits between the
          water pump and the timing case, the other 2 are behind the flywheel...
          and there is a big chance they may sweat/leak and then "Mama miaaaa"
          so the reason why you will never see these plugs being touched..
          Solution ? When BMW use to care on the old school S38/M30s they
          had serviceable plugs so that when the engine is rebuild one can clean
          the main galley and put back with thread sealant till the next rebuild.
          It is very tricky to do this conversion on S54 because the cross oil channel
          is very close to the end of the block and if one pushes the threaded plug too
          far it can block the oil passage.
          To make short thread it's very tricky! (even I have been told its not going
          to work....)The way I created this is via 2 taps. 1st is std and the function
          is to "Start" the thread, the other one is to cut to razor sharp depth distance and
          stop the thread so that next rebuild the person who is going to clean the block
          (if they do) will not be put into a risk. The Second tap I machined flat on the lathe,
          and if one suggests they sell taps which are designed for flat cut at the bottom
          is not going to work because they are not flat enough...! I need 0 zero.
          You will not believe the metal particles, gunk, dirt, shaving came out from the
          machining process. The final cleaning stage inside the oil galley is done on the
          engine stand with long brush thru the mains and thru the entire channel using
          solvent cleaner and compressed air. I use flash light on the opposite so that it
          will light up the entire tunnel/channel for visual inspection before I put the threaded
          plugs. Ones all is clean like in the picture then I am happy and the plugs are
          dressed with Loctite and it also acts like sealant, since they are tapered the
          torque is very light by hand and that is it.
          Clean assembly is crucial.
          All 4 plugs are converted now. Moving forward.
          Regards,
          Anri
            Happy Friday: I found another composite impeller
            blade but this time inside the Cylinder head, pic is
            from the side cooling manifold off.
            Not good at all.
            Regards,
            Anri
              Anri,
              Did you consider welding the pitted ridges between cylinders and then machine grind them down to the block top, maybe 0.002" instead of 0.021" , 10x more? They have been doing welding to repair cracked cylinder head combustion, and so I wonder why not on the cast iron block.
              Very nice works!
                Anri,
                Very nice works!
                Sapote,
                Thanks for your question and reply.
                I have tried to death welding cast iron block cracks or build material
                and I never ever ever had success in thin/slim areas like this one. Cast
                iron does not like to be welded in small areas. An example the Old School
                machine shop Hot/Rodders which closed few years back Harry(owner)
                who retired they use to weld Cast Iron heads for Diesel trucks but they
                would weld so much material like min 20-25mm+ and then he still never
                gives you warranty that the moment the engine starts and goes thru heat
                cycles will hold up.
                Thin areas like this I have tried with pre-heating technic to nearly
                red and used special welding rod from camshaft grinding company and
                never worked well. The cracks come back right away when the welded area
                is cooled down.
                Also remember by applying that much heat to the block, the top will
                warp so hard then I need to go next size pistons and no guarantee.....it
                will work..
                So the single choice to save this is what I am doing by cutting the block
                and then will make up with the Cylinder head gasket and the engine will
                never have any issues.
                Regards,
                Anri
                  Were is this going to stop?.....Its one surprise after
                  another...When I meant from parting out I really meant from
                  parting out !!! sapote cylinder head is aluminum and
                  welding a crack is a common practice.
                  Okay, so the block is now done and on the engine stand
                  ready to assemble.
                  After the block was finished I moved to skim the head
                  I set the head on the stand, put the marker paint and made
                  a micro pass to inspect if the head is set on the table flat, it
                  checked like 0.000002mm lol...which is totally fine.
                  Then set the machine to make my 1st pass at 3thousand-0.076mm,
                  Ran a pass and what do I see....fucking hidden micro cranks
                  were the compression was crossing back and forth.....fuck is
                  what I said loud.
                  I called local Hot-Rodder chassis fabricator who welds on
                  daily bases.
                  He came and ground the cracked area like ~8mm deep in
                  Arc but in flipped upside down orientation. He welded a bead then
                  stopped and started forging it with small hummer with half a moon
                  shape. Ones he forged the bead he started to weld on top and add
                  material and repeat the process 3-4 times.
                  Ones he was done then back on the decking machine. With the
                  welded areas I ended taking 7-8" thou or ~0.18mm which is
                  not that bad for what I am dealing with.
                  Regards,
                  Anri
                    Wow. That’s a bunch of stuff. Thanks for the tips on the oil passageway cleaning.
                    sry to see those cracks in the heads.
                    The lesson I’m seeing here (and that I learned first hand) is that all used s54s are not equal. The block/head interface is sensitive to blown HGs and delaying that repair incurs a ton of extra time, expense, and engjne build changes.
                    what HG will you use on this build?
                      Today's day was nearly ruined.....the composite water
                      pump piece was stuck hard in between the casting as
                      can be seen in the picture above.
                      I started very gently to push the piece but it was not
                      moving at all. Tried many approaches and was still
                      not moving, then increase the pressure and all of
                      a sudden the piece unlocked and ran on me inside
                      further in the cylinder head and completely got lost.
                      Then put grease on the seats again and back in the
                      water bath container. The container is just as big as
                      the cylinder head filled up with water all the way up
                      and started to pull the head from the water up in the air
                      so that the water drains from the head. After I repeated
                      this several times the piece came out from the Back
                      tapered water plug.
                      It felt very good to see the piece came out. I went with my
                      bore scope camera and checked the rest and seems
                      its now finally all clean.
                      Moving forward.
                      Regadrs,
                      Anri
                        The OEM pistons are still in spec. Cyl number 2 piston is replaced with a good one I
                        have exactly for this kind of situation/s and needs replacement of 1. The new/old
                        piston is totally in spec.
                        Every engine I rebuild re-using the OEM pistons with New rings like in this case
                        I make sure there is not a dot of carbon build-up left anywhere. Few months ago
                        I started using Aqua-Blast method cleaning parts. I am tired of the old school
                        rub-rub with a brush in parts washer...
                        In the picture on the far left is S54 piston, middle is S38-B35, and far right is S14
                        pistons being cleaned up for current on going engine rebuilds.
                        It is critically important to clean the ring land areas to be absolute free of dirt,
                        carbon etc...Each ring land has been closely inspected for potential cracks
                        after being completely cleaned up.
                          Again, clean parts and assembly is crucial when I assemble
                          engine.
                          A lot/most people have absolute no clue how much time it takes
                          to clean the parts to a level of how you see it in the pictures.
                          AquaBlast is knife with 2 edges, it is very physical work when one
                          is after to clean the engine parts. If cleaning crankshaft main cover is not
                          a big deal but when you start spending 1 2 3 hours my hand gets
                          sore because the gloves are hard and the Hi pressure requires
                          lot of muscle work out. Parts like the cylinder head It takes around
                          2 hours to clean, wash after its done and dry.
                          Moving forward.
                          Regards,
                          Anri
                            Great work, Anri.
                            Q: The high temperature and pressure gas leaked and cut through the cast iron wall between the cylinders, but why it didn’t cut through the softer walls on the head (except one with a hair line crack)?
                            It is amazing that the old pistons have almost no wear on the side and skirt from touching the cylinder wall. How?
                            Any measurable on the ring lands by the rings?
                              Great work, Anri.
                              I was shocked by the lack of wear on my 212k mile motor. The pistons spec’d out to exactly like new. Within the tolerance of a new piston. Every one. I have no idea how. The rings lands were the same.
                              the bores had opened up slightly, but only ~20% of total allowable wear. The rings were at double the bmw spec. They seemed to be the sacrificial anode.
                                Sapote,
                                Great work, Anri.
                                Remember the cylinder bores are Siamese on S54 engine and the heat is concentrated exactly in that spot.
                                That material is way hotter than the one on the head were the water sits. Its also the reason why when BMW increased
                                the bore from (S50B32 Euro at 86.4mm) up to 87mm they had to move to MLS gasket and single solution to
                                survive the increased heat and even then from age (not damage such overheating etc) they get tired and its time for
                                service. S5032 never burns gasket in this way in-between the bores. Its never common problem on them,
                                the older BMW engines the problem is corrosion on the gasket which leads to failure.[/QUOTE]
                                Answer: There are 2 main reasons.
                                A) Primary key/reason is the OEM pistons do have Graphite coating from new !!!!
                                B) If you pay attention the side skirts on S54 pistons the lines/groves are very deep and that is very good thing because
                                retains oil !!! If you take any aftermarket pistons they have those Coarse if I can use this word?, groves/lines.
                                At last is the expansion rates are very well calculated, I have never ever heard piston slap on S54s engines. Take
                                an older S38, S14, M30 etc...they have massive piston slap on cold start till they warm up.
                                The graphite coating+deep groves= to a absolute great lubrication operation and with the great hone from the factory
                                is the Engineering answer behind your question.[/QUOTE]
                                I work from ages on S38/S14/S54 and have not seen single one with worn out lands, at least the ones I worked
                                on rebuild re-using the OEM pistons. This is not subject of ware out area.
                                Moving forward.
                                Regards
                                Anri
