Porsche Brembo 996 BBK Conversion-- let's figure out how to fix the dust boots/seals
I've also used GiroDisc boots and seals, and have good results so far. Granted, this is for rear calipers only, which aren't getting quite as hot as my front brakes.
I bought some Brembo seals and boots (for my front Stoptechs) from Hoerr Racing (hrpworld), as Girodisc was out of stock at the time.
They respond fairly quickly to emails and might be able to help you about the Porsche calipers.
Apexperformance.net also sells a lot of Porsche stuff and might help as well.
For the rear calipers, sizes are 28 and 30 mm. Can't help regarding the fronts.
I found several websites selling blue colored seals, supposedly made from a Silicone high temperature material.
On this website you can nicely navigate by make and model and caliper part number.
I have no experience with this website or boot style, maybe someone else does, just putting it up for debate.
Just going to say that I’ve had good luck with the Girodisc dust boots. I only have a couple years and maybe 10 track days and 3000 miles on them but that’s better than OE Porsche apparently. Rotor temps typically around 600-650 F in the paddock after a cool down lap.
https://nam3forum.com/forums/forum/main-forum/e46-2001-2006/229329-porsche-brembo-996-bbk-conversion-let-s-figure-out-how-to-fix-the-dust-boots-seals?p=238109#post238109 Let's start off with the issue: The factory 996 seals don't seem to be able to take the heat of tracking. These were <500 mile old OE Porsche: This
This seems to be a fairly known issue in the Porsche community (probably worse for us, with our heavier and more powerful cars):
https://rennlist.com/forums/parts-ma...ure-seals.html
However, their solution is NLA with stoptech shitting the bed:
https://www.ohioperformancesolutions...-rebuild-parts
Stoptech shitting the bed, I say? Yes:
StopTech is broken and these rebuild kits have been difficult to keep in stock. The acquisition of StopTech (and Centric Parts) by First Brands Group was a total disaster. First thing the new owners did was cancel all open orders with existing suppliers and shift production orders to their own factories. No matter that they didn't have the tooling or the experience. So the rebuild kits quickly went on backorder and certain sizes have been unavailable for nearly a year.
Reach out to Pat McCleish <autobrakesolutions(at)gmail(dot)com>. He's a former brake systems engineer at Centric who left shortly after the acquisition. Now he has his own caliper rebuild parts company and he works with the former manufacturers for StopTech and Centric. So he can get you everything you need. Plus he's got extensive expertise on Porsche, exotic, and antique calipers. He's your guy!
The reason I'm not quite satisfied with that answer is that stoptech boots/seals were never amazing-- most people I know with stoptech brakes, that are reasonably quick on track, replace their seals every 1-3 years. Brembo seals are good for a decade+.
So, what I'm really looking for is a good way to buy OE brembo BBK seals in 996 caliper sizing, front and rear. Pat seems like a reasonable fallback (1-3 years is certain better than the OE Porsche good for <1 day on track at speed).
The OE Porsche seals are made by brembo, but, given how they (fail to) hold up to the heat of tracking, they must be using a different material than Brembo does in their BBKs.
So, I suppose 3 questions:
1) Does the 996 caliper have the same size piston:bore ratio as other brembo calipers, so the brembo BBK seals would plug and play in?
2) Does anyone know where Brembo BBK grade replacement boots/seals can be purchased?
3) ... what size boots/seals does we even need? Best I can find is "28/32/38mm Brake Caliper Rebuild Kit Porsche 996/997 GT3"
Does that means those are the sizes for 996 GT3? Or 996s and 997 GT3?
... I have an email in to Pat, to see if he can source Brembo seals. Will update this thread if he can.Tags: None
- Likes 3
