Porsche Brembo 996 BBK Conversion-- let's figure out how to fix the dust boots
  • Obioban
    Wahoo! Such excellent news.
    Will be installing mine this winter, once salt goes on the road, forcing the M3 off the road.
  • OPS
    heinzboehmer Glad you were able to abuse them and report back! It’s not as sexy but the piston seals are actually even more impressive! Speaking of which I now also have seals only for those running racing calipers! Ive weathered the tariffs and now can concentrate on bringing more options to the Motorsport community. I announce new products on our facebook page although I am still a dinosaur when it comes to social media,…
    Mike
    Ops
  • heinzboehmer
    Okay, I'm very impressed with the Frenkit dust boots.
    I was doing engine bay heatsoak testing at a recent track day and thought it would be a good idea to skip any sort of cooldown and park the car in the paddock as quickly as possible. Obviously, the front brakes started profusely smoking almost immediately after parking. Hopped back in, did a cooldown lap of the paddock and all was good.
    I swapped back to street pads today and was expecting to find some very destroyed dust boots, but instead I found this:
    They're still completely intact? What? How?
    I checked all of them and they're all still in perfect condition. Incredible.
    Also, this is what the track pads look like. I was not being kind at all to the dust boots at the track with how little thermal mass I had in there:
    These dust boots are the real deal. Thanks a bunch OPS for making these available to us.
  • OPS
    Nardo S54 Thank you for the kind words and it really is fun helping out fellow motor-heads! Looking forward to seeing the rebuild progress!
    Mike
    OPS
  • Nardo S54
    Just wanted to give a shoutout to OPS. Not only did my initial order arrive promptly, but he also went out of his way to help fix my order even though it was an error on my part. Most other companies would've hit me with a ridiculous restocking fee or tedious RMA process but not OPS. Mike was genuinely helpful in getting me the right parts as fast as possible -- it was like dealing with a fellow enthusiast as opposed to a typical vendor. I won't have chance to tear the calipers down for another few weeks but whether they last as long as the originals or not, I'm a repeat customer. Well to be fair, they'll definitely last more than the Porsche OE boots I installed 2 weeks ago. I put those in since I wasn't sure I'd get the OPS ones in time and they looked like this after 1 track day on DTC-70s.
    And for anyone wondering, full tear down will include pistons, boots & seals + titanium shims + mild brake cooling
    Click image for larger version  Name:	IMG_8783.jpg Views:	0 Size:	107.7 KB ID:	325423
  • OPS
    What I worked out with Frenkit were three options:
    1. Dust boots only
    2. Caliper rebuild kit (dust boots/piston seals)
    3. Caliper Rebuild Kit with Pistons (Dust Boots, Piston Seals, Pistons)
    The choice is up to how much of a rebuild are you planning on doing! These kits are an upgrade to the Brembo EPDM (rubber) seals. These can be used on street (it's just an upgrade) or the track.
    First choice is Rebuild Kit with Pistons. Only reason to get this kit is your pistons are shot, marred, or they went flying across the room when you disassembled them. If so you will need the following kits of you have the 996 calipers (front and rear):
    Fronts (Each kit rebuild ONE caliper)
    ApplicationsEach Kit Rebuilds One (1) Caliper 36/40 x 32mm Brembo Caliper Rebuild Kit with Pistons Included are the following components: 36mm High Temp Gray Silicone Dust Boot Quantity 2 36mm Pressure Seal, Quantity 2 36x32mm Piston OE specifications Quantity 2 40mm High Temp Gray Silicone Dust Boot, Quantity 2 40mm Pressure Seal, Quantity 2 40x32mm Piston OE specifications Quantity 2 Caliper Temperature Sticker - included free! Silicone Bleeder Caps Note: Silicone Dust boots must be assembled dry to prevent damage caused by grease. This kit services one (1) 36/40 x 32mm Brembo Caliper. Questions? Email us and we will be happy to help you [email protected]
    Rears (Each Kit rebuilds ONE caliper):
    Applications Each Kit Rebuilds One (1) Caliper 28/30 x 30mm Brembo Caliper Rebuild Kit with Pistons: Included are the following components: 28mm High Temp Gray Silicone Dust Boot Quantity 2 28mm Pressure Seal, Quantity 2 28x30mm Piston OE specifications Quantity 2 30mm High Temp Gray Silicone Dust Boot, Quantity 2 30mm Pressure Seal, Quantity 2 30x30mm Piston OE specifications Quantity 2 Caliper Temperature Sticker - included free! Silicone Bleeder Caps Note: Silicone Dust boots must be assembled dry to prevent damage caused by grease. This kit services one (1) 28/30 x 30mm Brembo caliper. Questions? Email us and we will be happy to help you [email protected]
    So if you dont need the pistons but need to do a rebuild the caliper you can save some money by buying the rebuild kits (Boots and piston seals)
    ApplicationsEach Kit Rebuilds One (1) Caliper 36/40mm Brembo Caliper Rebuild Kit (996 C2/C4, 997.1/2 C2/C4 & More) Included are the following components: 36mm High Temp Gray Silicone Dust Boot, Quantity 2 36mm Pressure Seal, Quantity 2 40mm High Temp Gray Silicone Dust Boot, Quantity 2 40mm Pressure Seal, Quantity 2 Caliper Temperature Sticker - Included free! Silicone Bleeder Caps Note: Silicone Dust boots must be assembled dry to prevent damage caused by grease. This is also an OE replacement for StopTech/Centric kit part numbers: 143.99036K - 36mm 143.99040K - 40mm Centric 143.37013This seal kit replaces OE Brembo Dust Boot part numbers: 20.4872.44 (20 4872 44) - 36mm 20.4872.46 (20 4872 46) - 40mmThis seal kit replaces OE Brembo Pressure Seal part numbers: 05.5955.56 (05 5955 56) - 36mm 05.5955.58 (05 5955 58) - 40mmThis seal kit replaces OE Brembo Rebuild Kit part numbers: 105.5955.56 (105 5955 56) - 36mm 105.5955.58 (105 5955 58) - 40mm This kit services one (1) 36/40mm Brembo caliper. Questions? Email us and we will be happy to help you [email protected]
    ApplicationsEach Kit Rebuilds One (1) Caliper 28/30mm Brembo Caliper Rebuild Kit: Included are the following components: 28mm High Temp Gray Silicone Dust Boot Quantity 2 28mm Pressure Seal, Quantity 2 30mm High Temp Gray Silicone Dust Boot, Quantity 2 30mm Pressure Seal, Part Number, Quantity 2 Caliper Temperature Sticker - included free! Silicone Bleeder Caps Note: Silicone Dust boots must be assembled dry to prevent damage caused by grease. This is also an OE replacement for StopTech/Centric kit part numbers: 143.99028K 143.99030K 143.37009 This seal kit replaces OE Brembo Dust Boot part numbers: 20.4872.40 (20 4872 40) - 28mm 20.4872.41 (20 4872 41) - 30mm This seal kit replaces OE Brembo Pressure Seal part numbers: 05.5955.52 (05 5955 52) - 28mm 05.5955.53 (05 5955 53) - 30mm This seal kit replaces OE Brembo Rebuild Kit part numbers: 105.5955.52 (105 5955 52) - 28mm 105.5955.53 (105 5955 53) - 30mm Centric 143.37009Questions? Email us and we will be happy to help you [email protected]
    OR if you just need dust boots you can order the sizes you need here: (for this example you will need to order two 36/40/28/30mm sizes for a total of 8 kits)
    Looking just to replace your crunchy, heat damaged Brembo dust boots only? We are now pleased to offer the Frenkit Performance Dust Boots sold in pairs for those not needing a complete rebuild! With over 50 years of brake manufacturing experience, Frenkit Performance uses a proprietary high-performance, high-temp peroxide-vulcanized silicone rubber designed for durability. This silicone has excellent mechanical properties, performing reliably between -60ºC and +200ºC without breaking down and handling temperature spikes up to 300ºC with ease! Each kit contains two (2) dust boots Note: Silicone Dust boots must be assembled dry to prevent damage caused by grease!
    Hope that helps!
    Mike​
    OPS
  • OPS
    Originally posted by Nardo S54 View Post
    ​Just placed an order for fronts!
    All packed up and ready for me to drop off at the PO tomorrow am!
    Mike
  • Nardo S54
    Originally posted by OPS View Post
    Dust boots arrived and I have updated the inventory on the site. Sizes 28-44mm are available!
    Mike
    OPS
  • OPS
    Good winter project that you can take your time on!
  • Tonggi
    Tonggi are you running the 996 fronts and rears? Or something else?
    Mike
    When I change out track pads I will confirm part #s for you. I plan to do this rebuild during the winter.
  • OPS
    DBA (Disk Brakes Australia) who makes very nice 2 piece rotors did a heat test on the Frenkit Performance dust boots.
Name:	Screenshot 2025-10-09 at 4.19.20 PM.png
    Mike
    OPS
  • Obioban
    Ordering!
    Just to short cut everyone...
    Fronts are 36 and 40. Rears are 30 and 28. You will need 8 total kits for 4 calipers.
  • OPS
    Mike
    OPS
  • OPS
    I feel your pain! I must have thrown away 500 dust boots...
  • Tbonem3
    On no they're grey! I'm having PTSD from stoptech boots
