Originally posted by bigjae46
View Post
TC Kline Rear Spring Question
Originally posted by S54330Ci View Post
MCS is by far a superior damper to anything TC Kline can come up with and the best damper for those who track their car.
it should be important to note most people will not see or realize any gains on the street running a race damper over a more street oriented damper.
usage case scenario is more important here. OP should probably state what type of driving and how much of it they plan on doing
I am curious why the OP thinks he needs 700lb springs in the rear. Way too much spring for casual street driving not to mention what the ride quality would be like. What he probably needs to do is increase the rebound settings, and possibly a small bump up on the compression setting on his rear dampers. This will firm up the rear without compromising the ride quality.Last edited by S54330Ci; 09-05-2023, 10:01 AM.
Maybe the reason everyone runs MCS is because they are the best. Being different for difference sake is not going to make your car faster or handle better. Really kind of a stupid metric to base an important decision such as damper choice on. MCS is by far a superior damper to anything TC Kline can come up with and the best damper for those who track their car. Their damper technology is superior to anything else out there. I should know as I run their 2WNR (coil over rear) on my 330Ci track car.
What kind of damper technology does the MCS have that makes them superior? It looks like a pretty standard monotube shock to me, except they have a convenient compression/rebound adjuster through the shaft.
Dampers Buyers Guide | Motion Control Suspension | Motorsport & Premium Dampers
Certainly these dampers are not for everyone, but if you are serious about building a high-end track car (or race car) then these are the dampers to get. β
A 50-80mph turn is where my car or I am weakest. Which is apparent when I run track near DFW which mostly have those mid speed, trail brake turns. My theory is the car is kinda lazy from the extra compliance which is hurting and the aero hasn't really ramped up with the speed...or it could be the driver. I need some more time to really decide that. But the car feels significantly more planted and responsive turning in at 120mph than it does at 75mph.
Its all about trade offs. With higher spring rates and aero you lose some mechanical grip so you lose some speed in low speed turns and exit speed. That will help you at one track and could hurt you at another. I could run stiffer springs at the DFW tracks (smoother, mid-speed turns) but then I think it would be less optimal at my home track in Houston (bumpy, low and high speed turns).
If you're hardcore, maybe switch springs between events.
Is the car "lazy" at initial turn in or mid corner (or both), and what is your antiroll bar setup?
In this case I think a slightly later turn in will help but only so much. If I could just change the rear springs, too easy. Changing the front springs is more of a pain - removal, installation, ride height adjustment, toe and camber changes...all more of a pain on the front axle.
I have an OE front roll bar and no rear roll bar.Last edited by bigjae46; 09-06-2023, 03:16 PM.
Originally posted by bigjae46 View PostIf I could just change the rear springs, too easy. Changing the front springs is more of a pain - removal, installation, ride height adjustment, toe and camber changes...all more of a pain on the front axle.
I have TCK DAs on my car. I recently dialed in the car a bit and the rear seems a bit soft. I am running 500# springs in the back. I am considering 700#.
The car is mainly used for weekend / cars and coffee duty. Am I going to ruin the ride?
I think itβs more spring than you need for cars and coffee, but it seems spot on for track duty on a car still driven to/from the track.
