Adding / removing Pins from the fuse box
    Hi,
    I am looking to modify my fuse box by adding some pins for new Fußes (Race abs) and removing others for deleted functions.
    I searched the net, but I have not found anything for e46, only earlier Models.
    Does anyone know how the get the pins that the fuse taps into out?
    Any what is are the part numbers for new Pins?
    They are Most Likely in that page somewhere https://www.realoem.com/bmw/de/showp...diagId=61_2156
    Since I have my interior Out and the fuse Box exposed, I want a clean install and not tap into things.
    Thanks!
    You need a special tool, might want to look at a BMW repair instruction to get the part number of the tool.
    If you have the fuse box out just use a wire coming out the back of the fuse box from a deleted circuit. Then crimp/heat shrink - no solder!
