Originally posted by heinzboehmer
I actually love pedantic people because that is the only one way
to go further ahead and improve and mostly understand.
I did not wanted to go into deeper details but I have to now.
Note: I mentioned in my previous post that I can calculate
so called effective final drive ratio.
But in more simple language for those who does not know
how to calculate.
In order to calculate the effective final drive ratio one
needs to take the gear ratio and multiply by the differential.
SG6 4.35x3.62=15.747 effective final drive.
G420 4.23x3.62=15.312 effective final drive
The chart you post is fine but because the curves are not
very clear vs speed vs rpm and it makes it little bit confusing
not as clear as the chart bellow. I made very nice excel charts
so I can see things in close details when I calculate tires size,
vs HP vs TQ vs RPM vs Speed etc.
It's like dyno-chart if you print the chart to show the HP vs RPM
in say 20rpms increment vs a curve.
In the chart I made for us here pay attention on the speed
vs rpm vs RPM drop vs TQ vs speed.
So now if you look at the HP chart vs the SG6 rpm drop then
you will see loss of HP not by much but S54 needs every single
hp and tq in the world.
Something to suggest when you compare setup it does not
matter what it is you need to be fair and measure the rest to be
the same, in this case will be use the same tires size for both
gear box comparison. Because if you tweak one you can tweak
the other as well.
The rpm drop from from 1st to 2nd will affect the HP with around +/5-RWHP
and that is +/-9hp at the crank I can make the chart even closer to each other
but its a lot of work..the point I am making I think its understood.
I agree whit you, this is very small detail which will not be noticed day to day
driving but 0-60mph selling nonsense it does make a visual difference
if its 5sec vs 4.8sec its a window sticker mind game...back in the year of 2000.
(If anybody wants help with the differential gear ratio for the track, or tire size
let me know I will apply the data and reply)
Regards,
Anri
