Hi Gents,
Another S54 in the pipe line is on the go. This S54 it came out of
convertible E46M3 with 180k miles on the chassis...The original engine was
replaced with this specific and the milage is absolutely unknown. Engine ran
great pulled hard and no issues at all. I did quick compression check test before
the engine was removed from the car and all 6 it showed 175psi perfect healthy
engine with unknown miles...
This engine is going to E30M3 and I decided to tare the engine apart perform
inspection and do refresh.
The concept with this S54 is what most customers aim for. Healthy engine,
Schrick 288/280, Karbonius air box, tuned on pump 91octane.
At present the engine is all apart and the single issue I found is a broken
tab on the Vanos hub. Up on close inspection on all the parts I can safely say
this engine has never been open nor received any Vanos service nor bearing
service.
Starting with the block. The typical Electrolysis surface damage which is normal
considering people do not service the Coolant every 2 years....so the block needed
clean up.
The material removed from the block was +/- 3-4 thou with finish under 50rA. The
"0" mark is aaaaalmost gone so it will need thicker gasket for sure.
The bore edges are all kissed to avoid absolute any ring damages during installation,
it's must to do. (I know of at lest 3 people who chipped a ring during installation after
the block is decked)
Regards,
Anri
service.
clean up.
Regards,
Anri
