Hello,
I completed my subframe reinforcement, which involved removing the tank, filler neck, and charcoal canister.
After reassembly the car started and ran for a few minutes before I turned it off. I then started it again the next day and it ran fine but I noticed a hiccup. Then, the next time I started it the idle started bouncing until it stalled and I can start it now, but it will eventually stall. It’s got no power at all.
I took out ISTA and read the codes. There were many - Im assuming some were already in the memory before the issue started (note that the car is new to me and I don’t know its history). I remember potentiometer 1 and 2 (which I believe to be related to TPS), and fuel pump relay.
In order to troubleshoot, I cleared the error memory to see which code would stay, and the Pot are gone but the fuel pump relay came back.
I replaced the two relays in the trunk area on the passenger side: a green one and a black tall one which I understand to be the fuel pump relay.
I then cleared the codes and put the key to ON (without starting the engine), and the code didn’t immediately come back. When I started the engine, and re-scanned the code was back (fuel pump relay).
I realize it could be a bad pump but Im hesitant at throwing more expensive parts at the car without a proper diagnostic. Especially since the pump does work at least enough for the car to start. I’m looking for a course of action to properly pinpoint the source of the problem.
Did anyone experience a fuel pump relay code while the fuel pump relay was in working order ? I’m also curious about how the DME detects a bad fuel pump relay. Could it be related to fuel pressure or is it a current measurement at the pump? Could I be dealing with a clogged filter or fuel lines? Could it still be my TPS even if the Pot codes don’t come back?
