Turner Adjustable Front Sway Bar End Links
    Looking to order a set of these. Does anyone know offhand what the proper length to order is for a lowered car? 170mm - 185mm is the default on ECS but there are plenty of other ranges available.
    How low ? Subtract amount lowered from stock height, should put you in the ballpark.
    purchase link with adjustment either way from midpoint. Would seem logical.
    2004 M3 Mystic Blue
      Yeah, I'll eventually do that if no one knows the answer already. I'd thought I'd ask because my car is hard to get to right now until I clean out my garage.
        My hub center to wheel well arch is 13.5 "
        I have TSU4612AF3 TMS adjustable sway bar links
        hope this helps
        2004 M3 Mystic Blue
          Connected to H&R 30 mm 3 way adjustable away bar
          2004 M3 Mystic Blue
            Lucky for you I just went through this same process
            My car came with the Turner upgraded sway bars, but the previous owner had reused the stock endlinks (no bueno when properly setting the sway bar without preload on a lowered car). So I just recently bought and installed the Turner Adjustable endlinks. I had reached out to Turner and they recommended the below for my car and setup (Turner sway bars and coilovers with a normal moderate drop) and said its the one they recommend on most E46 M3s:
            TSU4612AF3
            250mm-265mm
            https://www.ecstuning.com/b-turner-m...104~dk/?pdk=CA
            Fit perfectly and car actually felt better on turn-in, and more stable mid corner 👍
            2004 CB/Cinnamon 6MT Coupe
            Youtube
              BigRussia Mystic3 Did either of you have any clunks with these turner links? Just installed some new ones and having this issue.
              🔹 2001 M3 Laguna Seca Blue
              Instagram: link
              Build thread: link
