When I rebuilt the pump with all new seals and a new motor, I made sure to remove the solenoids one by one and test them using a 12v source and they tested out all the same/fine. I used a guide online to confirm they were put back in the same spot also.
The car drove fine in between now and after I rebuilt the pump. the clutch space bleeds out fine and I can hear it working correctly. All gear changes using INPA are good. Activating the solenoids in INPA are also successful which is why this is so frustrating.
I'm leaning now into thinking either my INPA installation is somehow causing the procedure to fail or there is a wiring fault somewhere that only presents itself in this way since the clutch works otherwise.
