OP, what are you doing for the airbag sensor? Reuse OEM one from your old seat, buy a new OEM one, etc? Looking to get Sportster CS's soon as well.
Obioban, thanks for sending those links for the brackets. Very helpful.
Questions About Recaro Sportster CS Seats
Not a problem!Originally posted by DiscoWagon View Post
Oh I see that now, I stand corrected. Wasn't aware that AMX would sell just the covers, good to know!
For those interested in seeing a naked seat: https://www.instagram.com/s/aGlnaGxp...26115225141714
Oh I see that now, I stand corrected. Wasn't aware that AMX would sell just the covers, good to know!Originally posted by Inizes View Post
He put the covers on himself though I believe. AMX only provided them?
His seats were reupholstered by AMX Performance.Originally posted by Inizes View PostI think pb_e46 on Instagram re-covered his recaros himself. He might be a good person to reach out to for info on this. I don’t know if he used the heating pads.
I've never taken a set of CSs apart, so I don't know how feasible it is. but if it is possible, might be better to get a set without seat heater pads and install BMW seat heater pads instead.Originally posted by duracellttu View Post
Thanks for the info! I’m going to find a set without airbags.
I’m assuming these Brey Krause mounts are preferred over the Recaro sliders due to the addition of height and tilt functions? They don’t seem that heavy at 3lbs each.
I have ZCP manual seats right now. Not sure exactly which parts need to be reused? The sliders that bolt to the floor of the car?
The Recaro sliders need some sort of adapter to bolt to the floor, and a seat belt mounting solution-- the net result is heavier, higher, and more expensive than BK mounts + OE sliders.
The OE sliders also have ~double the travel of Recaro sliders, so back seat access is easier. The Recaro sliders can get noisy over time, which isn't great. And, the OE sliders are designed to have the belts mounted above them (unlike the Recaro sliders), so the seat belts stay properly located to the seat, regardless of slider position (unlike with the recaro sliders, which aren't strong enough to take the seat belt load in a crash).
If you have manual factory sliders, you'll also need BK's slider release handles.
Yeah, just the sliders are reused. The install process is seen here:
http://qnuwm.rpstd.servertrust.com/v...ions/R9246.pdf
- Likes 3
Thanks for the info! I’m going to find a set without airbags.Originally posted by Obioban View Post1. no idea.
2. yes
3. Yes-- unlike many other cars, the e46's side airbags are built into the doors (not the seats). Double side impact airbags is not a recipe for success. You could not hook them up, but then you're just paying extra for extra weight. I'd buy a set without them.
4. Yes. Brey Krause makes mounts for them that attach them to the factory e46 power or manual sliders.
https://www.ecstuning.com/b-brey_krause-parts/driver-mount-for-e46-e85-e86/r-9246~brk/
https://www.ecstuning.com/b-brey_krause-parts/passenger-mount-for-e46-e85-e86-/r-9247~brk/
Follow up question: no, not with recaro's seat heating pads. To do that, I used BMW's seat heater pads, with their integrated thermistors.
1. no idea.
2. yes
Follow up question and related. Is it possible to wire up the heating function to the factory heated seat buttons with the 3 settings?
Hey! I'm about to buy a set of Recaro Sportster CS seat and wanted to know if you could answer a few quick questions for me.
1) Are these the right part numbers for the seat for the e46 M3? 411. 10. 1785 and 411. 10. 2785 (Black Leather, Heated)
2) Do all variations of the Sportster CS fit in the e46 M3?
3) These have airbags built in to the side, never seen them on other e46 M3s. Any issues with that?
4) I assume the seats are all standard then mounting brackets are different to fit the e46 M3.
Thanks in advance for the help!
