Questions About Recaro Sportster CS Seats
  • Obioban
    You can also tweak the seat eater values, thiugh I forget how at this point. I found I was never using level two, so I made my level two the factory level three and made my level three more intense.
    Did all this back when I still had stock seats, but sine I used e46 seat heater pads in my seats... still applied equally.
  • 9kracing
    Someone else mentioned that, or maybe it was you in another thread, but mine seem to work fine.
    I'm not measuring exact temps or times, but I don't notice anything different than stock
  • duracellttu
    But they don't heat up as fast as the stock ones And I found the heat set point targets to be off as well.
    +1 this is my experience as well.
  • Bry5on
    Ask Marek what he does.
    My seats work with the factory heat buttons.
    https://amx-performance.com/
    But they don’t heat up as fast as the stock ones And I found the heat set point targets to be off as well.
  • 9kracing
    Originally posted by trancenation View Post
    has anyone been successful at wiring the recaro heaters with the OEM harness? i know some vendors make a plug and play retrofit, but was wondering if there was a DIY out there.
  • Bry5on
    They won’t work properly, the electrical impedance is fundamentally incorrect. I retrofitted mine with e39 heated seat elements for factory like operation (OEM button) and quick heating. Prior to that I’d attempted to use the recaro/aftermarket style heaters.
  • trancenation
  • Bry5on
    will there be any sensor faults in the seats that we need to program out? if i were to get CS's i would intend on having the passenger seat sensor installed. etc.
    I wired a resistor in so that the passenger airbags will always trigger, then ended up coding it to the same behavior anyway, just to take the guesswork out. Retrofitting the sensor into the CS looked like it could have been tricky and unreliable, so I opted to just always trigger the airbag and delete the sensor. No faults.
  • trancenation
  • EthanolTurbo
    Custom brackets are coming together, currently the final version is out for powder coat. Updates here: https://nam3forum.com/forums/forum/m...lack-tan-332it
    v1:
    Click image for larger version Name:	D639F6C9-CA92-4012-A099-7FCF57579D71.jpg Views:	0 Size:	147.3 KB ID:	198873
    v2:
    Click image for larger version Name:	Screenshot 2022-12-17 at 9.04.41 PM.png Views:	0 Size:	550.2 KB ID:	198874
    I would like to test these out sometime. Looks really compact and streamlined.
  • WestBankM4
    v1:
    v2:
    Fantastic Bry5on. Since you're the same exact size as me and I plan on moving towards the CS shortly, I'll be utilizing this custom bracket if/when you make it available! Great work man.
  • Bry5on
    I've had to in the past, design my own seat mount using steel/aluminum purchased at Home Depot. Luckily the OEM brackets from my 1986 Toyota Corolla mounted to my custom base to fit some Brides. I'm a bit worried I'll be doing the same because I am also looking at the CS's and thus far being 6'2, 200lbs, 34" waist, there doesn't seem to be a good solution.
    Besides custom building a set Bry5on, you don't have any other leads? May be leaning toward the Nogaro's if push comes to shove which would be a shame because I just love Recaro's and used them in a lot of my previous builds.
    v1:
    v2:
  • Bry5on
    Does anyone know of a good guide to disassemble these seats? I've got a clients car here with Sportsters and the tilt feature is not working, looks like a cable came unclipped somewhere. I'm reluctant to start prying on plastic without knowing the repercussions on a clients car, lol.
    Thanks, George
    Basically you pull the covers off and most is revealed. I’m not sure about the seat retract, but here’s a photo with the foam removed where you can see the cable routing (foam just sits in place after the covers come off).
    1) unbolt 4 Allen fasteners to remove seat bottom
    2) remove trims and pry away seat back cover (see video https://youtu.be/DNThViXutg4)
    3) lift off foam
    Click image for larger version  Name:	FC6F2F29-9430-480C-93D2-3170BBB013C1.jpg Views:	0 Size:	122.2 KB ID:	198867 Click image for larger version  Name:	8C6B72B9-9328-4442-A661-294649890AE3.jpg Views:	0 Size:	134.8 KB ID:	198868
  • George Hill
    Thanks, George
  • usdmej
    Overall, I can’t say I’d recommend these brackets. Looks like I’ll be designing and cutting/bending my own replacements soon.
    Highly recommend you try the Swiss cheese mounts (VAC, Macht Schnell) if you're looking for lower seat height. Even with sliders they sit a sportster cs significantly lower than stock
