Code 154 (Crank Case Breather/Venting) - Seeking Solutions
    Thank you ! Hope it works !
      If you're getting this code it's likely a bin from a newer model year versus older.
      Send your tuner the link above and it should be a 10 minute change to fix it.
      This makes sense,
      I was the one who did their DME repair and since their BIN they sent me was corrupted i BDM flashed a saved file from a 2006 DINAN ZCP HP DME i keep around. didnt even consider that it would throw that DTC on older car that didnt have the PCV sucking jet solenoid .
      Stilt if Hassan cant do it, then I can manually delete the DTC for you in the file. just let me know.
        This makes sense,
        I messaged Hassan, we will be doing it soon. No worries !
