DME: where to buy the Freescale MCU chips?
    I Google the part number but didn't see any availability -- could be a specific part number for Bosch or Seimens. Maybe I should search for a generic part number instead?
    I remember someone said the MCU is belong to the MC683xx family, but I would like to confirm the exact part number to order. They are with 160pin package option.
    I'm helping someone with a damaged DME caused by jump start with a booster batt -- they disconnected the booster too soon before the onboard batt voltage recovered high enough, and the disconnect might have caused a very high voltage on the 12v bus due to Load-dump and fried one of the MCU (it's getting hot with 5v applied).
      I used this datasheet for my little rabbit hole on trying to replace a MCU, it's also suggested that these MCU have internal fuses or something inside it that is pre-programmable by the manufacture. I'm not 100 sure if this is the case with our DME because I haven't bought a MCU or did in depth research but these are links, I've used in the past. Hope this helps point you in the right direction.
