I currently am lowered with some style 359m ZCP e90 comp wheels on the e46 m3 .
The tyres rub the fender a little and on turns. Rear is rubbing on the inner fender on a turn
I currently have -1.3 deg camber in the front and -1.7 in the rear.
Tyre specs are
245/35/19 19x9 + 31 , 6mm spacer = 19x9+25
275/30/19 19X10 + 25
My height is 13.5in front , 13in rear.
If I wanted to get -2 camber in the front, can I simply swap the top hats? I dont think I want/need more than -2 deg of camber. Im guessing if I just do the pin swap , I may be able to get a bit more (-1.5?)
How much more camber can I get in the rear or have I maxxed it out?
Tyre specs are
