F8X M3/M4 CF Drive shaft mod
  • Corradoloco
    I did mention “crusty” scale lol, before I install it I’ll take better measurements promise hahaha
  • usdmej
    Wasn't Slonik trying to claim it's only 1-2 lbs lighter than stock? Lol.
    seems like a lot has been lost in translation, it doesnt help they mentioned converting a mazda RX8 driveshaft and threw in weights for that too
    Originally posted by Slonik View Post
    e46m3 driveshaft weight (with cv joint) - 8.5kg​ (18.7lbs)
    F8x cf driveshaft (with joint also, but different type, looks lighter) - 7.6kg (16.7lbs)
    converted with rx8 cf driveshaft
    6070g (13.4lbs)
    so if i've got little bit more than 2kg drop on rx8 driveshaft, i don't think that you can get anything less than 7.5kg on f8x, maybe even heavier.​
  • Slonik
    m4 shaft weight 16.7lbs, so when he got 12 lbs on his scales, i'd recommend to use some more accurate scales. closest supermarket with vegetables scales waiting
  • EthanolTurbo
    Originally posted by Corradoloco View Post
    ​​​​​On my crusty scale …
    Stock M3 shaft w/ cv joint = 19 lbs
    Stock M4 shaft w/ cv joint = 12 lbs
    Modded M3 CF shaft w/ cv joint = 11 lbs
  • Corradoloco
    stock m3 shaft weight also includes carrier bearing.
  • 0-60motorsports
    Awesome thanks for posting!
  • Obioban
    That certainly seems like a bigger weight drop than we were expecting!
  • Corradoloco
  • 0-60motorsports
    Anyone made any progress especially SMG Folks
  • PipeUy
    The driveshaft arrived at Uruguay, probably going to wait to do it together with a Wavetrac and probably 4.10 gears but it's nice to have it here.
  • George Hill
    Originally posted by e46IX View Post
    I wonder what kind of MPG the S54 is capable of with that 8-speed and a modest diff ratio.
    I don't want to muddy up this thread with 8HP stuff so maybe I'll start a dedicated thread, but to your question the 8th gear and 4.44 ratio is almost the exact same as a 420g 6th gear and 3.62. With the Turbo Lamik it is hard to keep it in 8th on the highway in automatic mode as any slight throttle causes it to downshift. Swapping to the 4.44 vs the 3.15 I had in it was night and day different but still not ideal. My car generally gets mid to low 20s pure fast highway.
  • e46IX
  • George Hill
    Originally posted by enjoy_m3 View Post
    Hmm, man I was considering an 8hp after watching the aussies do it on their cars for my daily wagon. What's the trade off George?
    Drivability is pretty crap. I mean its ok, but a daily driver you want to drive everyday doing mundane tasks I'd say its a lateral move from SMG, maaaaaybe even down grade.*
    *I run a TurboLamik controller and their aftersales support is atrocious. I would never run or install into anyones car an HTG. CANTCU is not ready for MSS54 DMEs yet. MaxxECU (Standalone ECU) is working on their own 8HP protocol which I am looking at for another build. BUT if you are on a standalone (not just Maxx) then you can use a CANTCU as well
  • enjoy_m3
    Depends on what you call a "thing" lol. It works, but not as good as a stock car and certainly not in an upgrade in all areas.
    That I do, reason I can run a 4.44 diff ratio and am asking about driveshaft speeds.
  • George Hill
    S54 + ZF8 is a thing now?
    Originally posted by Will View Post
    I think George Hill has this setup in his wagon.
