F8X M3/M4 CF Drive shaft mod
  • nyc951
    Are there THAT many F80 cars getting salvaged nowadays? Or are people stealing these carbon driveshafts like catalytic converters 🙃?
  • Cronenberged
    +1
  • nachizl8
    Originally posted by Cglhut View Post
    Depending on cost I may be in as well.
    +1
  • SQ13
    ^ Same
  • Cglhut
    If you get a couple modified and batch order with your driveshaft shop, I’m game to cover your time/costs for at least two to make it worth your while.
  • Bry5on
    If anyone needs these locally in SoCal, I will have some available for pickup.
    If you get a couple modified and batch order with your driveshaft shop, I’m game to cover your time/costs for at least two to make it worth your while. I’m in San Diego frequently.
  • Cglhut
    You putting one of these driveshafts on your turbo car? Curious to know how much power these driveshafts are good for!
  • nyc951
    Are there that many F80 M cars being dismantled? Where are these retailers getting these driveshafts from?
    The Porsche 944 has a one piece driveshaft / torque tube - talk about a pain to drop.
  • Consum3r
    If anyone has a contact for a trusted shop that can do this mod preferably in the NJ/PA/NY area please share.
  • heinzboehmer
    How does it work on F80s? Do they also have to move the diff back?
    Edit: Ah, looks like there's enough slack in the F80 CV to push the driveshaft back and slide it off the transmission flange: https://youtu.be/lofGPVOPWPc&t=267
  • Obioban
    Happily there not that many projects that need the driveshaft to come out. But, yeah—will be more of a pita.
  • e46IX
    hoping not to dampen the mood as the platform interchangeability and potentially low cost of this mod is very interesting
    but having to drop your subframe just to install/remove a one piece driveshaft seems potentially really . . . . tedious
    Just loosen the differential and move it back, but yes no doubt it becomes a PITA anytime you're doing something which requires removing the driveshaft. The stock driveshaft is a breeze to remove.
  • bimmerfan08
    Originally posted by Altaran View Post
    You don't have to drop the subframe. Just loosen the diff mounts to be able to push back and fourth the diff.
    Yep. Or just time it with a diff swap/upgrade, for example.
  • Altaran
  • usdmej
