Originally posted by usdmej
F8X M3/M4 CF Drive shaft mod
BTW i took my driveshaft back to the shop, explained the issue andnthey said they will work on it. I noticed the CV joint has no articulation or potential movement once installed so that could be it.
They claimed it could be my diff mounts etc... they're OEM other than the poly bushing so I gotta imagine they would vibrate less than a solid solution.
They might also have me bring the car over to check it out in person. Stay tuned. The CF driveshaft might be going back in my car.
This is from mine. However this was pulled from a database.Originally posted by bigjae46 View PostCan anyone pull tthis measurement? Has to be from the car. Worst case, I can wait until this weekend to get a measurement.
“the dimension from the face of the rubber flex disc installed on the transmission yoke to the face of the rear CVJ yoke on the differential.”
Hopefully it's the same for 6MT and SMG cars…..Originally posted by bigjae46 View PostCan anyone pull this measurement? Has to be from the car. Worst case, I can wait until this weekend to get a measurement.
This 100% and warranty even if it's only for a year is better than nothing.Originally posted by x Spades x View Post
Understood, thank for doing this!
OK, I'll get a shaft this week and look out for the upcoming process.
I do agree that we should find an established shop that can balance them to perfection.
Understood, thank for doing this!Originally posted by bigjae46 View Post
You would need to buy on and then contact my contact.
While I could make some money by facilitating the transaction…I’m doing it to help the community. I’ve certainly benefitted from others doing leg work to get a vendor on board.
What's the torque rating on the F8X cf driveshaft? Aside from turbo and superchargered cars most cars with aftermarket running M/A won't see torque above 450ft lbs.
From the vendor:
“So we offer a one year warranty parts and labor. The only exception is if vehicles are tuned beyond the capabilities of the components.”
If the shaft blows apart then probably wouldn’t fall under warranty. High speed vibration - should be covered unless he shaft is showing signs of being subjected to high levels of torque.
Thank you for doing this! I'm sure we all appreciate it.Originally posted by bigjae46 View Post
While I could make some money by facilitating the transaction…I'm doing it to help the community. I've certainly benefitted from others doing leg work to get a vendor on board.
You would need to buy on and then contact my contact.Originally posted by x Spades x View Post
Would we buy our own and ship them or will you be sourcing them and going through your contact?
- Likes 3
Would we buy our own and ship them or will you be sourcing them and going through your contact?Originally posted by bigjae46 View PostStill working on some details but so far…
$800 shipped. Only need the F8X driveshaft. They source the flanges and parts. I’m waiting for more details -
​​- can I provide the CV joint and guide bushing?
- are the flanges machined, reused from a different shaft?
- what is the warranty?
- does it cover high speed vibrations?
let me know if I need to ask any other questions.
I would be more inclined if we can find a single source/shop that will do these right and not mess them up as opposed to some others who tried a shop and it didn't work. $800-1000 is decent for this mod and worth it at that cost imo.
