F8X M3/M4 CF Drive shaft mod
That’s ~double what I paid to have my e60 M5 driveshaft shortened for the 6mt conversion 🤔
Yeah true. But here labor will be much cheaper so let's see if I can get it done or I'll have to ask someone in the States for a hand in getting it done there.Originally posted by EthanolTurbo View Post
It's not too bad honestly. Ideally $700-900 would be the sweet spot but about $1k for an OEM CF driveshaft is not a bad deal.
It's not too bad honestly. Ideally $700-900 would be the sweet spot but about $1k for an OEM CF driveshaft is not a bad deal.Originally posted by 0-60motorsports View Post
That's great if you could take detailed shots and measurements that'll really help me being thousands of miles away to get this mod done. $775 is steep including the donor so thank you for doing this.
I will measure everything once it's complete.Last edited by EthanolTurbo; 02-02-2024, 11:35 AM.
That's great if you could take detailed shots and measurements that'll really help me being thousands of miles away to get this mod done. $775 is steep including the donor so thank you for doing this.Originally posted by EthanolTurbo View PostUpdate: at the driveshaft specialist now. He is doing the measurements and we will begin modifying it today. Should be done in a couple days. Progress!
This isn't a cheap job though. This place is charging about $775 labor and parts. I'm going to bite the bullet for the sake of data but will be trying another shop for future driveshafts. These guys know what they're doing so it's worth the initial hit I suppose. That puts total cost at around $1075 for me. I am using my old stock E46 M3 driveshaft as a donor but according to this thread the 330i driveshaft will work as well and is peanuts cost-wise.
Hoping to have this installed middle of next week.
- Likes 3
Thanks JoshOriginally posted by TheElite///M3 View PostHi I'm waiting on my driveshaft and found a shop to cut/weld/balance. Will try my first documentation to help
the community. Will be also changing all motor mounts/oem guibo/racing diffs 3.95/mounts. Pretty much whole drivetrain refresh in terms of mounting points. I cant wait to report on NVH since this build is almost at 200k mi.
Glad to be part of this community with this platform, shocking how much is interchangeable from e30-f8x maybe even g.
-Josh
RacingDiffs is garbage, don't waste your time.Originally posted by TheElite///M3 View PostHi I’m waiting on my driveshaft and found a shop to cut/weld/balance. Will try my first documentation to help
-Josh
-Josh
I did mention “crusty” scale lol, before I install it I’ll take better measurements promise hahahaLast edited by Corradoloco; 02-01-2024, 01:23 PM.
seems like a lot has been lost in translation, it doesnt help they mentioned converting a mazda RX8 driveshaft and threw in weights for that tooOriginally posted by EthanolTurbo View Post
Wasn't Slonik trying to claim it's only 1-2 lbs lighter than stock? Lol.
Originally posted by Slonik View Poste46m3 driveshaft weight (with cv joint) - 8.5kg (18.7lbs)
F8x cf driveshaft (with joint also, but different type, looks lighter) - 7.6kg (16.7lbs)
converted with rx8 cf driveshaft
6070g (13.4lbs)
so if i've got little bit more than 2kg drop on rx8 driveshaft, i don't think that you can get anything less than 7.5kg on f8x, maybe even heavier.
m4 shaft weight 16.7lbs, so when he got 12 lbs on his scales, i'd recommend to use some more accurate scales. closest supermarket with vegetables scales waitingOriginally posted by EthanolTurbo View Post
Wasn't Slonik trying to claim it's only 1-2 lbs lighter than stock? Lol.Originally posted by Corradoloco View PostOn my crusty scale …
Stock M3 shaft w/ cv joint = 19 lbs
Stock M4 shaft w/ cv joint = 12 lbs
Modded M3 CF shaft w/ cv joint = 11 lbs
Awesome thanks for posting!Originally posted by Corradoloco View PostOn my crusty scale …
