F8X M3/M4 CF Drive shaft mod
I did mention “crusty” scale lol, before I install it I’ll take better measurements promise hahahaLast edited by Corradoloco; 02-01-2024, 01:23 PM.
seems like a lot has been lost in translation, it doesnt help they mentioned converting a mazda RX8 driveshaft and threw in weights for that tooOriginally posted by EthanolTurbo View Post
Wasn't Slonik trying to claim it's only 1-2 lbs lighter than stock? Lol.
Originally posted by Slonik View Poste46m3 driveshaft weight (with cv joint) - 8.5kg (18.7lbs)
F8x cf driveshaft (with joint also, but different type, looks lighter) - 7.6kg (16.7lbs)
converted with rx8 cf driveshaft
6070g (13.4lbs)
so if i've got little bit more than 2kg drop on rx8 driveshaft, i don't think that you can get anything less than 7.5kg on f8x, maybe even heavier.
m4 shaft weight 16.7lbs, so when he got 12 lbs on his scales, i'd recommend to use some more accurate scales. closest supermarket with vegetables scales waitingOriginally posted by EthanolTurbo View Post
Wasn't Slonik trying to claim it's only 1-2 lbs lighter than stock? Lol.Originally posted by Corradoloco View PostOn my crusty scale …
Stock M3 shaft w/ cv joint = 19 lbs
Stock M4 shaft w/ cv joint = 12 lbs
Modded M3 CF shaft w/ cv joint = 11 lbs
Awesome thanks for posting!Originally posted by Corradoloco View PostOn my crusty scale …
Modded M3 CF shaft w/ cv joint = 11 lbs9 Photos
- Likes 8
The driveshaft arrived at Uruguay, probably going to wait to do it together with a Wavetrac and probably 4.10 gears but it's nice to have it here.
I don't want to muddy up this thread with 8HP stuff so maybe I'll start a dedicated thread, but to your question the 8th gear and 4.44 ratio is almost the exact same as a 420g 6th gear and 3.62. With the Turbo Lamik it is hard to keep it in 8th on the highway in automatic mode as any slight throttle causes it to downshift. Swapping to the 4.44 vs the 3.15 I had in it was night and day different but still not ideal. My car generally gets mid to low 20s pure fast highway.Originally posted by e46IX View PostI wonder what kind of MPG the S54 is capable of with that 8-speed and a modest diff ratio.
Drivability is pretty crap. I mean its ok, but a daily driver you want to drive everyday doing mundane tasks I'd say its a lateral move from SMG, maaaaaybe even down grade.*Originally posted by enjoy_m3 View Post
Hmm, man I was considering an 8hp after watching the aussies do it on their cars for my daily wagon. What's the trade off George?
*I run a TurboLamik controller and their aftersales support is atrocious. I would never run or install into anyones car an HTG. CANTCU is not ready for MSS54 DMEs yet. MaxxECU (Standalone ECU) is working on their own 8HP protocol which I am looking at for another build. BUT if you are on a standalone (not just Maxx) then you can use a CANTCU as well
Hmm, man I was considering an 8hp after watching the aussies do it on their cars for my daily wagon. What's the trade off George?Originally posted by George Hill View Post
Depends on what you call a "thing" lol. It works, but not as good as a stock car and certainly not in an upgrade in all areas.
That I do, reason I can run a 4.44 diff ratio and am asking about driveshaft speeds.
Depends on what you call a "thing" lol. It works, but not as good as a stock car and certainly not in an upgrade in all areas.Originally posted by e46IX View PostS54 + ZF8 is a thing now?
That I do, reason I can run a 4.44 diff ratio and am asking about driveshaft speeds.Originally posted by Will View PostI think George Hill has this setup in his wagon.
