Originally posted by Derek //M
F8X M3/M4 CF Drive shaft mod
There were a ton available, I looked before I posted or I would have bought one already too, lol
Why I went ahead and picked one up on eBay just now! I can already see this mod going mainstream…can't lie tho, I'm still tripping out off the price of these things..Originally posted by Derek //M View PostUntil we all start trying to snatch them up online at the same time 😂
Bonded.Originally posted by discoelk View PostIs the welded steel section bonded to the CF or is it removable somehow?
It’ll be cutting off some portion of the stock f8x steel parts, welding on the e46 flanges (carefully managing heat and setting the lengths to e46 driveshaft length), and then balancing the final assembly.
I have a local driveshaft shop I’m pretty confident in— they shortened the driveshaft for my e60 M5’s SMG to 6mt conversion, and you’d never know it wasn’t stock. Completely smooth at all speeds..
I’m going all in— using the flanges from my current, stock driveshaft rather than sourcing new parts. No easy back tracking for me
- Likes 3
The shop that I used specializes in servicing driveshafts. For the main part the shop has to have excellent welders and experience with balancing shafts.Originally posted by PSUEng View Post
What kind of "shop" would one be looking to find to do this kind of work? Any particular flanges to use (BMW part, or...?). I'm very interested in this, looks like you can't buy new shafts--so eBay is the purveyor of choice here?
No, you can't buy them new. BMW stopped using CF shafts in the M4 when they had to start using particle filters in Europe. (When downgrading to a smaller diameter steel shaft it created more space to fit the filter in the exhaust). At least that was the official explanation.
330 driveshafts use the same flanges as the M3. And they are cheaper than used M3 shafts.
Wow, these are so cheap, following with great anticipation, lol.
What kind of "shop" would one be looking to find to do this kind of work? Any particular flanges to use (BMW part, or...?). I'm very interested in this, looks like you can't buy new shafts--so eBay is the purveyor of choice here?Originally posted by enjoy_m3 View Postfrom internet searching, it looks like the f80 driveshaft is said to be 1477mm and realoem states 1404mm for e46 m3 driveshaft. So looks like as long as the shop can lengthen 73mm (2.87") with the correct flanges and have it balanced.
Having it balanced will be my biggest issue in Bahrain.Originally posted by enjoy_m3 View Postfrom internet searching, it looks like the f80 driveshaft is said to be 1477mm and realoem states 1404mm for e46 m3 driveshaft. So looks like as long as the shop can lengthen 73mm (2.87") with the correct flanges and have it balanced.
from internet searching, it looks like the f80 driveshaft is said to be 1477mm and realoem states 1404mm for e46 m3 driveshaft. So looks like as long as the shop can shorten 73mm (2.87") with the correct flanges and have it balanced.Last edited by enjoy_m3; 01-12-2024, 08:59 AM.
Great mod. Definitely interested in feedback once someone gets one of these installed.
Lucky bastards 🤣
Hopefully someone from here will be able to help me out when this is figured out for SMG cars. Thanks guys.
