Hey, need some help with the car. The car won't start. It only crank. Read code P1434. Thanks.
2005 M3 with 200K miles - Car not start but it crank. Read code P1434
If fuel pressure is good then I wouldn't change the pump.Originally posted by yabmane View PostI checked both of those are good. I am thinking of changing the fuel pump. I am not sure when is the last time my car change the fuel pump.
If sparks are good, then remove the air filter and spray some starting fluid and try to crank again and if it's running then injectors not getting power.
