"Vin is Faulty". Can a faulty instrument cluster cause AKMB read issue in NCS Expert?
    Hi all,
    As the title states, I have an issue in NCS Expert regarding the AKMB module in my car. I try to read the ZCS/FA of the AKMB on NCS expert but a series of fault codes pop up:
    VIN is faulty
    COAPI-1081: GM-Schluessel fehlerhaft FFFFFFFF
    COAPI-1080: Codierschluessel fehlerhaft FFFFFFFFy
    FFFFFF80EF020332 80C91D004AR
    COAPI-1000: Fehler
    In INPA, I get an error code when reading the instrument cluster: IFH-0006: COMMAND NOT ACCEPTED. Program will be stopped!
    In both programs, all other modules can be read with no issue so I'm ruling out problems related to the K+DCAN cable, configuration of the COM Port, and anything related to configuration settings.
    In another thread I read about a similar issue, and their root cause was a cluster short circuit. They then replaced the cluster and was able to proceed with reading the module.
    '02 M3 6MT - Carbon Black/Dove Grey
    '08 X5 6AT - Platinum Bronze/Nevada Beige
    '01 325i 5AT - Orient Blue/Hell Beige (Sold)
    '06 325i 6AT - Arctic Metallic/Black (Sold)
    Instagram: @kylen.m3
    What if you try read your FA from the LSZ instead?
    edit: Looking at the error again it seems to me like it's either trying to perform ZCS operations, or the car is ZCS and it's trying to do FA operations on it and it's failing.
    Do you have a 09/2001 or earlier?
      Hi! Thanks for taking the time to respond.
      To answer your question, I actually tried reading it from ALL available options in NCS Expert (AKMB, ALSZ, EWS, KMB). I have an 06/‘02 build date so that would mean it
      should read from either the AKMB or ALSZ.
      I am in the progress of sourcing another M3 cluster to test my theory of whether the instrument cluster would cause this or not.
