A reminder. If the flat tire monitor illuminates.
In order for the Flat Tire Monitor to learn the correct tire inflation pressure, do the following:
1.Check the tire inflation pressures in all tires
2.Compare them with the tire inflation pressure table on your door rocker panel.
Initializing the system.
Each time you correct the pressure in a tire, or change a wheel or tire, reinitialize the system immediately afterwards. This requires a bit of driving.
1.Before driving off, start the engine but do not start driving
2.Press the button as long as you need to until the yellow indicator lamp in the instrument cluster lights up for a few seconds
3.Drive off. It takes a few minutes before the Flat Tire Monitor can detect a flat tire and issue a warning.
