Search in E46 (2001 - 2006) only
Vehicle Discussion
E46 (2001 - 2006)
m3
gashby
Junior Member
Jan 2024
m3
01-24-2024, 03:13 PM
m3
gashby
05-16-2024, 09:17 PM
Shonky
Feb 2021
01-24-2024, 11:16 PM
Is it only oil?
How did you clean?
Sounds unrelated to me unless you left something disconnected?
WestBankM4
Nov 2020
01-25-2024, 10:04 AM
ICV and Throttle Bodies are related to airflow and A/R, they don't have any thing to do with oil. Did you unplug something during the process? Sounds like it's unrelated, did you get underneath the car and find the trail?
D-O
Mar 2020
01-25-2024, 11:18 AM
Breather hose on the bottom of the manifold not correctly re-attached?
Old, not obsolete.
AWE46M3
Aug 2022
01-25-2024, 07:08 PM
Originally posted by
D-O
+1 double check that hose as it connects to the dip stick/oil pan. What you're describing sounds like an oil pan leak
AWE46M3
01-25-2024, 07:12 PM
02
M3 Alpine White /
Cinnamon
@alpinem3
m3_sancho
Member
Jul 2021
01-26-2024, 11:42 AM
If you have SMG, your hose to the reservoir might be not connected properly.
sapote
Moderator
Jun 2020
01-27-2024, 12:59 AM
m3_sancho
I vote for this.
sapote
Moderator
Jun 2020
01-27-2024, 01:00 AM
D-O
This should cause lean codes but OP didn't say, so I think he has SMG and its oil leaking.
gashby
Junior Member
Jan 2024
02-09-2024, 07:26 PM
It was the Oil cooler line, It failed. On to my next issue!
