Originally posted by r4dr
Who's Using the DB9 Caliper Brackets?
That variation is between pad manufacturers, not the pad shapes. Technically the Aston's pad shape is D1165, which is just a D1001 (STI pad shape) with a wear sensor cutout and a different pad material profile along the top arc. Centric, for example, specs both at 14.9mm. However, if you don't care about the wear sensor cutout, D1001 is going to be cheaper and more readily available. They are all 15mm or just below. Some manufacturers (Pagid 2487, for example) spec 16mm because they know there's extra room in the caliper.Originally posted by liam821 View Post
They're the same pattern, but it seems most of the Aston brake pads are 15mm thick while most of the STI brake pads are 14.9mm. With that said, I used a 14.9mm pad (Centric Posi Quiet), and Zechkausen lists the same pad part number for both cars.
- Likes 4
They're the same pattern, but it seems most of the Aston brake pads are 15mm thick while most of the STI brake pads are 14.9mm. With that said, I used a 14.9mm pad (Centric Posi Quiet), and Zechkausen lists the same pad part number for both cars.Originally posted by enjoy_m3 View Postjust to clarify, the pad shape is the same as an 03-04 sti? (based on the link from zechkausen)
The 44/40 pistons should also help to avoid the tapered pad wear from the 40/40 pistons that people have reported.
They are not the same, however, look very similar. The Aston has a 40/44 brake caliper piston size, while the Renault's has a 40/40. The smaller piston in the Renault calipers gives it a more rear bias brake bias which is closer to stock - by like 1%. You'll probably never notice the difference.Originally posted by Mr.wReckless View PostAre those the same callipers that are part of the Freakyparts Renault RS kit? They look similar..
Regards
If I was doing this again I wouldn't hesitate to buy the Aston or Renault kit, they're both very similar and look better than the Porsche caliper IMHO.
It should be noted that the older Brembo GT 355mm kit for e46m3's (4-piston caliper) used the same 40/44 piston size.
Here is a picture of the Brembo GT caliper from my old car.
- Likes 3
Regards
Our caliper bracket is almost done; it will be for the 345mm rotor without the spacer. The spacer works, but a one-piece design makes me feel a little better about it.
Just to add, zeckhausen.com has all the caliper rebuild parts and a bunch of pad options all in one place: https://www.zeckhausen.com/catalog/i...th=440_441_442
I run Centric Posi Quiet D1001 63-105-1001 for the DB9 (you can grab them from zeckhausen.com or rockauto.com etc). They're quiet, don't make much mess, work fine in wet/cold, and are just fine street pads. I've never had any fad on the street. The initial bite when cold is a bit meh, but once you get a bit of heat in them they're great. And for the money - they're like $75 - it's a fantastic choice IMHO.
What pads are you guys running? I'll post some pics of my stuff later today, I have to start assembling the front end anyway.
