My carbon roof has seen better days. I’ve noticed my headliner damp around the a-pillar sun visor. We just had a big storm and while none of the carpet was wet, I pulled my gm5 to find a ton of moisture near the wiring. On top of that, my cluster wouldn’t turn on after I replaced my leaking tail light and turns but it’s working now. Scary!
I just went through major leak repair on my Touareg due to VWs infamous clogged sunroof drains.
I have not pulled the headliner yet but have a few questions:
1. Do cars with sunroofs have drain hoses leading to the pillars like my VW? I don’t have a sunroof anymore, is there supposed to be drainage in the A-pillars which might be clogged or does water drain from the roof rails on the exterior down between the glass and a-pillar?
2. Can the rubber trim around the windshield and rear glass be removed and replaced without removing the glass?
3. Has anyone removed a bonded CF roof before? Sounds like fun.
Im planning to replace my roof at some point but with lead times and installation that could be some time before it gets fixed.
