I ran the DIS VANOS test twice today and got the results below. The first test failed but the second test, around 20 minutes later, passed.
The exhaust side is leaking. Is this usually faulty valves in the valve block or the sealing plate between the valve block and the VANOS unit?
Do the other results look ok?
First test results:
Reached position, inlet late: 58.6 °KW
Reached position, inlet early: -1.5 °KW
Reached position, outlet early: -4 °KW
Reached position, outlet late: 44.6 °KW
Deviation leak test inlet: 2.5 °KW
Deviation leak test outlet: 5.1 °KW
VANOS system outlet leaking
Procedure:
1. replace VANOS solenoid valve set
2. repeat function test
3. if error occurs more frequently (>50%),
Early adjustment time inlet: 209ms
Late adjustment time inlet: 200ms
Early adjustment time outlet: 195ms
Late adjustment time outlet: 217ms
Second test results:
Reached position, inlet late 58.4 °KW
Reached position, inlet early -1.6 °KW
Reached position, outlet early -3.9 °KW
Reached position, outlet late 47 °KW
Deviation leak test inlet 1.4 °KW
Outlet leak test deviation 3.9 °KW
Early adjustment time inlet: 224ms
Late adjustment time inlet: 229ms
Early adjustment time outlet: 235ms
Late adjustment time outlet: 228ms
All actual values correspond to the setpoint values.
VANOS system in order.
First test results:
Procedure:
