CPM Brace Bar.. Any experience? (CLRF-B001)
    Greetings - came across this.
    Has anyone used this/have it? Link below:
    Brand CPM Series Name BRACE BAR Product Number CLRF-B001 Compatible Car BMW E46 M3 Product Description Since CPM Lower Reinforcement is attached to the chassis frame, it cannot be seen unless it is lifted up after installation. However, just because it is an invisible place, there is no compromise in its manufacturing.
    Does it replace something existing on our cars or is it an add-on?
    Thanks!
    Figured it out, delete
      Well fill us in any info is good info.
        It looks like it replaces the two chassis stiffening plates under the car, one attaches to the exhaust as well.
        Email to [email protected]
          i like this option over the rogue pieces, curious what the weight is on it
            Interesting you say it connects to an exhuast pipe. I'm not sure how, but I wonder - wouldn't that bring more drone and vibration ino the cabin?
            Seems like an area that doesn't need "improvement."
              Yes, this bracket connects to all E46s exhausts, other chassis have a similar design as well. It has a rubber isolator.
                I thoiught he meant in a way different than or inaddition to what stock does.
                You have to have something to hold up the midpipes.
