I didn't drive the car for a week, came back to a dead battery, I replaced the battery about 3 weeks prior. Check charging system thru the hidden menu, and see 14.0v at start up. Then it drops to 13.7v-13.8v ,at idle and driving. Is that the normal range or should it be 14.0v and up?
Alternator?
How do you determine it's a dead batt?Originally posted by M3powerzz View PostI didn't drive the car for a week, came back to a dead battery,
Hidden dispay shows 13.7v is good, but the DME gets the 13.7v before the batt post, so the batt may have less than 13.7v of the cable was not tight on the post and didn't charge it properly.
So when the engine running, measure directly at the batt two posts.
Let us know how it goes. If the battery isn't getting 13.6-14+ volts you will need to check voltage drop of the battery cables. Test from the positive post to the alternator output post, DVOM on DC V. Expect to see very little voltage <.5 v. Then do the same from battery negative to chassis ground and expect similar results. If either cable shows more voltage drop replace cable/clean connections etc.
The total cable voltage drop should be measured this way:Originally posted by Zack View PostLet us know how it goes. If the battery isn't getting 13.6-14+ volts you will need to check voltage drop of the battery cables. Test from the positive post to the alternator output post, DVOM on DC V. Expect to see very little voltage <.5 v. Then do the same from battery negative to chassis ground and expect similar results. If either cable shows more voltage drop replace cable/clean connections etc.
engine idling, measure alternator output post to the body, then compare to the measurement at battery posts.
I check the voltage from the alternator to body, it was 14.2v, also checked the positive post in front passenger side of engine , 14.1v. Then I checked the battery post is 13.9-14.0v. Put a amp clamp on negative cable by battery, when car is shut off is .031 amps.. after 15 mins it went down too .003 amps.
The data are perfectly fine.Originally posted by M3powerzz View PostI check the voltage from the alternator to body, it was 14.2v, also checked the positive post in front passenger side of engine , 14.1v. Then I checked the battery post is 13.9-14.0v. Put an amp clamp on negative cable by battery, when car is shut off is .031 amps.. after 15 mins it went down too .003 amps.
