Tested and Ready 70° and 75° Thermostat
    Hi,
    My suggestion is in such hot environment getting 75C is
    waist of time. If its my choice I would go with 70C for sure.
    I will sent you PM back.
    Thanks,
    Anri
    Thanks Anri. I wanted to go for the 75c because that should be good enough for the cooler weather too.
      Okay sure. This is the primary reason why I added 75C for cold environment.
      Not sure how cold it gets in Bahrain during those winter days but I will tell you
      if its like in California during coldest winter time were I am still walking around with
      shorts outside then this isn't cold enough....
      Anyway, 75C is.
      Regards,
      Anri
      www.euroclassicmotors.com
        Hi Anri, I would like one of your thermostats.
        Is 75⁰C only needed in very cold climates?
          X2. How do we buy this?
          2003.5 SG/Grey
            Sent me PM with your name, shipping address, and
            choice.
            Also in the payment put a Note your Forum user name so I can
            recognize who is who.
            Thanks,
            Anri
              Jae,
              I specifically underlined that the Check
              engine light will NOT turn on.
              I just put 900 miles on the test car and out
              of those 400 miles were on a 60F morning starts.
              On 55C the check engine light will turn on..
              one can turn it off from the ECU menu but
              its cold for daily.
              I have to ask Tomba and I hope he can
              share some data at 70C if the OEM map is out
              of Enrichment mode?
              Regards,
              Anri
              Oh, I was thinking this was the 55c t-stat. Makes sense now. You're killing me with the celsius...lol
                Anyway, 75C is.
                Regards,
                Anri
                Can you better define "cold environments"? In the PNW winter driving ambient temperatures are around 0-5C, but also summer track events are running during 30-35C days... Will the 70C thermostat be able to handle all of those conditions? Or is the 75C thermostat the more optimal option?
                I tried to ask these questions in PM but have not heard back. Figure the information could be helpful to others as well.
                2003 LSB/LSB 6MT Coupe | BUILDJOURNAL | CAE RACING | DMG AUTOSPORT | SUPERSPRINT | 996 BREMBO BBK | ENKEI | RAYS ENGINEERING | MOTORSPORT HARDWARE | OHLINS | GROUND CONTROL | BIMMERWORLD | TURNER MOTORSPORT | REDISH MOTORSPORT | DR VANOS | BEISAN
                  Here’s a datalog driving uphill at 90-100*F with a stock relatively refreshed cooling system and AC on full blast. Coolant temp got up to 94C at steady state and coolant gauge registered just below the 3/4 dot. Hope this helps. https://datazap.me/u/bry5on/hot-uphi...oom=9655-26853
                    All PMs replied.
                      Thanks for posting.
                      The other day I logged my test car during test and
                      I was 450 C pushing 500 C EGTs on 95-105F weather.
                      You are running only 104 C kind of odd.
                      Regards
                      Anri
                        Thanks for posting.
                        I was on nearly 450 C pushing 500 C EGTs.
                        Regards
                        Anri
                        My math calculation for EGT is wrong in my datalogger! I haven't spent the time to figure out the correct calc from the raw DME log. Any chance you have that off hand? I can then fix this one [and my future] logs. Good catch, it's the last one on my to-do list.
                        I also mistakenly took GPS altitude out of this log, but you can approximate it by following the ambient pressure drops
                        edit: Also realized I broke my gear calculation in my last parameter change. Fun, fixed that now.
                          [QUOTE=Bry5on;n269630]Good catch/QUOTE]
                          Yes this is with my OBD life data stream scanner.
                          I will post in a few days.
                            Anri If you can lock down the purchase for me I can install and test the 75c TSTAT in 125-140f weather and monitor coolant temps too. Thanks.
                              radiator outlet temps near 60°C during cruise, after some pulls it gets higher and we drive slower. Still engine temps <90°C which seems really OK from my side.
                              Only mods = CSL airbox.
                                These are most likely the same thermostats found on dodge diesel and peterbuilt engines.
                                They are compatible with s65/s85.
                                On s54 you will have to remove the middle gasket and install the OE O-ring in the thermostat housing.
                                they are like 15$ a pop.
                                70/160 Degrees
                                75/170 Degrees
                                80/180 Degrees
                                90/190 Degrees​
