Originally posted by Cronenberged
Tested and Ready 70° and 75° Thermostat
Meaning clean the bugs out of finsOriginally posted by ac427 View Post
Hi Anri, Thanks for the thermostat.
What do you mean by "bugs free AC condenser"
Thanks for sharing your experience, its for sure win win.
I have mentioned times and times that the t stat will NOT change the peak
temp at the race track. But but but it will prolong/delays the heat soak ones
you begin the session which allows you to buy more laps.
Fan clutch with early engagement+bugs free AC condenser is must.
Regards
Anri
Would you recommend heat wrap or ceramic heat powder coating for the headers to keep the radiation heat lower?Originally posted by Anri View PostGents,
To each to our won for sure on this one.
Not very constructive replies..
Inline 6 cylinder engine Cast Iron block
is waaaaay too long.
When the cooled water from the radiator
enters from the cylinder 1 it takes the heat
up to cylinder 3 aka Bank-1
Starting from Bank-2, 4-6, the water already
took the heat from Bank-1. Now Bank-2
has Hot water to work with and its no longer
cool when it entered the block.
Factory design water pump impeller and
pulley ratios are designed to work at 8000rpm
without making Cavitation, this is the concentration
I am sure we all agree on this one. Mechanical
pump are always concentrated to work at hi rpm
and low rpms are always compromised. (this is
were the Electrical water pump is priceless one
can adjust the flow at low speed to move the
water faster)
Lower range of RPM is compromised when
the water is slowed down tremendously and
thus why Bank-2 works always hot vs Bank-1
Obvious reason why BMW moved to step water
temp gauge starting from E32/E34. On the E24
E28 when the temp raised degree by degree I can see it
on the gauge..I can see when the clutch engages and
brings the temps down...isn't that obvious ? all the S54
cylinder head gaskets are always burned at Bank-2 okay
not talking about the ones that suffered damages
via detonation.
Why BMW put the EGT sensor on Bank-2 not Bank-1 ?
Bank-2 runs always hot
The Block Deck height on S54 is 217.5mm+/-
How come no one talks about that BMW Motorsport
raised the Floor by around 15-17mm ? (I have to look at my notes)
its to increase the rigidity in the main bearings
area by taking some space form the water bath.
On S38 at the same deck height of 217.5mm the water
bath is deeper down by those 15-17mm is what I am
comparing with so they did good on block from 1965
but went backward on 2000 engine block.
With connecting rod ratio of 1.52 the siamesed
bores do receive a lot of heat and with the combo
of 8000rpm for sure its Heat-Bomb
How come no one talks about that the EGT from
the headers which easily reaches ~850/~1000F/ 590°C or
so are located around no more than 1 finger away
from the block, fantastic, you have 900F radiant heat
going directly to the cast iron heat sponge.
I will provide very deep detail data on Jonathan's
freshly put S54 together, you will see.
Starting from Jonathans M3 I am including this in every
engine build.
All arguments and debates are all welcomed.
Regards,
Anri
agreed, it definitely delays the peak temps by 1 lap or 2 depending on the track. But on the street it takes longer to warm up esp in the FL heat.Originally posted by Anri View Post
Regards
Anri
Sachs Brand I believe is NLA for our cars.
that is not good. They sell like a
hot bread...I don't know why Sachs no longer makes those....
Behr is not my cup of tea.
Hunt for Sachs Fan clutch left over in parts stores NOS (new old stock) I am sure they are out there
sitting on shelf.
Originally posted by m3_sancho View Post
Sancho,
The T-Stat on the right is from E39M5/E34M5.
The Motorad is garbage brand which is not operating as advertised.
I have tested them many times and they never ever open at the advertised
Celsius.
Let alone that tons of people from other car manufacturer ended up with
stuck closed thermostat which you don't with our BMWs...You don't want
to play cheap in this area believe me...
I will say it again, I DO NOT USE Motorad garbage as some people may possibly
think I do.
Hi,Originally posted by Grke46m3 View PostHey Anri,
Don't know if this was covered but with the 70 degree tstat where does the temp needle sit on the gauge cluster?
Usually the needle sits around 2mm past the dot on the temp gauge.
Make sure your AC condenser is free of bugs and also Sachs fan clutch,
to take full advantages. Just buy those OBD ports from online and you can
plug it to OBD port and your phone and you can monitor the temp while you
are driving.
Regards,
AnriLast edited by Anri; 05-09-2025, 07:30 AM.
Originally posted by Tonggi View Postjust to give everyone an update. 70c tstat is great. def keeps temps a lot lower when cruising around the streets. at the track it didnt make a difference of course since the car gets to temp and hot. But it did cool down the motor a lot since it will keep kicking through the radiator up to 70C versus the OEM.
But Im not sure if its the only thing since I also updated the radiator and fan clutch
Regards
AnriLast edited by Anri; 05-10-2025, 05:49 AM.
- Likes 3
Yes, ok so that's that then LOL. I guess it'll go on the shelf.Originally posted by m3_sancho View Post
Hey Anri,
I have one but i never got round to installing itOriginally posted by m3_sancho View Post
Did you try these? I don't think they fit. They are bigger in diameter and do not fit the housing.
Did you try these? I don't think they fit. They are bigger in diameter and do not fit the housing.Originally posted by ZiMMie View Post
You can use those number to interchange to other manufacture.. e.g. ACDelco part # is also available. Etc.
You can even buy these thermostats from Porsche as they compatible with the Carrera GT.
https://motorad.com/part/880070/#interchange
https://motorad.com/part/880080/#interchange
https://motorad.com/part/880090/#interchange
