Tested and Ready 70° and 75° Thermostat
  • digger
    That’s the function of air intake, not the coolant.
    colder just makes more power. There’s a big difference in torque
  • oceansize
    While there are some "hillbillys" in drag racing (just like every form of motorsports), when you are running at these levels and ARE competitive it takes a pretty sharp individual with a VERY large check book. Comparing those cars would be more in line with comparing to a GT4 car. *I just wanted to note this because if you try to tell Sapote my data came from hillbillys he's really going to dismiss it (not that he probably wouldn't anyways).
    I love hillbillys . My entire family from top to bottom qualifies and their ingenuity is unsurpassed. Necessity is the mother of all invention applies.
  • sapote
    it has been mentioned already, its higher air density when cooler
  • George Hill
    George Hill gave you the example but you did not catch it, those Hillbilly with no regulations for quarter mile they don't care how much fuel they burn...those 8-9Litre push rod engines producing 1200-1400hp in NA form make the F1 engine kinder garden and those FI engines making 3500-4500hp puts F1 engine into trash bin..
    LoL, Anri has definitely spent some time in the South cause that statement is the truth.
  • oceansize
  • Anri
    I don't see how a 70C engine helps in giving more power -- cool cylinder walls rob the heat (and power) off the combustion gas as the delta temp is higher. I love to hear the reason for better power with 70C cool engine.
    The modern cars with mapped Tstat lower the coolant temp to avoid micro-boiling around the exhaust valves during high load, but they don't operate around 70C most of the time as someone just replace a stock Tstat with a 70C Tstat.
    Sapote,
    I believe you are ignoring a lot of data said so far.
    Inline-6 cooling design and the negatives, cast iron
    block with aluminum head, coolant path, detonation and, combustion
    chamber temp vs coolant, actual material like piston, cast iron actual temp,
    conditions and engine will keeps the most efficient tolerances, exhaust
    valves temperature transferring to the seat, cast aluminum head max temp
    were it will turn soft..ignoring the fact that every single road car is emission
    regulated and NoX must meet standards, period.
    I believe you false the meaning "Cool" EGT of 1200-1500F in
    some cases, this is by any mean absolutely not "Cool". Your example on
    the F1 engine is not constructive at all. You are forgetting that F1 engine
    is also after fuel economy no F1 team wants to carry 20kg more fuel..
    To start F1 engine the water and coolant must be pre-heated to 60°C
    and the still needs warm up period all of that to work with hi engine
    temps, in their case the Hi temp has nothing to do with the HP which
    I believe you are mixing the package.
    bin..
    As George suggested I can build you 105°C thermostat and your
    operating temp will be like exact on F1 engines and lets go to the race
    track and check your data on the straight line max speed and enjoy
    the low speed due to massive detonation....
    The best Teacher of how it works is when one starts to push limits
    and you really see what works and what it doesn't, on theory is easy..
    Regards
    Anri
  • George Hill
    I guess for these engines there is no radiator and so this is to make sure the whole block is cold enough for not getting overheated during the race. This is not related to the subject of cooler engine is good for power though.
    We are talking about engines that make 2000+hp, but still it DOES make more power. And no this is not to keep them from overheating, yes that is a by product but not the ONLY reason.
    When I was into american V8s we had my 468ci pontiac engine on the dyno and we were making back to back pulls with consistent numbers, we then cooled the water temp down, made a pull and it picked up power. (they were showing me how you can manipulate dyno numbers by the way it is operated, we also picked up power by sitting the RPM right below peak for a few seconds before starting the pull).
    Maybe Anri can make you a 100*c tstat and you can report back on how much better it is?
  • digger
  • sapote
    Originally posted by BBRTuning View Post
    Yep as mentioned lower coolant temp and higher oil temp up to a point is ideal from a power perspective. On my last engine build the OE thermostat that was in the car would operate around 70-72C for whatever reason, when I replaced the cooling system on my latest build it runs “correctly” at 80-82C now. Always wish I could get that old (worn?) thermostat back.
    I’ve actually started collecting parts to run an electric pump, have The CNC blockoff plate and was going to PWM control a Pierburg EWP in the Emtron ECU. Using closed loop you can easily target 65-70C under load and 85-90c during cruise and idle for efficiency for example. New OE performance cars (Porsche etc) do exactly this using electronic thermostats and EWPs, often running close to 100-105c at light load and dump the coolant temp when being driven hard and/or in Sport/Track mode.
    I looked into a custom thermostat as well but looked troublesome. If this happens I may just ditch the EWP project for simplicity!
  • sapote
    When I was helping with the drag race cars Mid/upper 4's in the 1/8th mile (not BMW), we would connect the cooling system to refrigerated cooling system which would get the coolant down to near freezing. It would not be uncommon to have the blocks sweating because they were so cold when we would pull them to the starting line.
  • Anri
    This is great! I'll buy a 70C anyway when they're available and just run that at least for now, the EWP was more of a fun project to play around with but simplicity sounds nice..
    Beau,
    Years back I read Tech article from I dont
    remember from Behr or Wahler that in case
    they go bad they will alwasy stuck open, it
    has to do something with wax mixture they use
    inside and the proportion. This will explain why
    your old one and the one I still have is opening
    early, its on its way out.
    This design thermostat started life on E34M5.
    This is hi flow design comopared to the older traditional
    style design. Ever since every manufacture started
    using this type of thermostat. The E34M5 t-stat is in
    S62 engine as well.
    Regards,
    Anri
  • digger
    This activated the fuel enrichment, not because engine is more efficient or higher performance.
    oil lubricants is best above 100C,
    more friction loss with cool cylinder walls.
    everyone knows lean is mean so enrichment will slow you down....the coolant and oil temp are not the same, nevertheless there is some coupling between the two but you can always drop down the viscoity if the oil temps are too low but this is not normally an issue on endurance type racing engine. Ofcourse on a drag racing engine they will run thin oils due to low oil temp and other reasons
  • oceansize
    Hi,
    On FI running cooler temp is a must coolant and oil.
    Supercharges do create constant drag to the crank
    and loads the system means will generate more heat.
    Are you running fan clutch or E-fan ?
    Regards,
    Anri.
    Thanks Anri. I'm running a fan clutch.
  • Anri
    Anri
    Do you think there is an application for this in a street driven supercharged car? I'm running a conservative 5.5 pounds of boost.
    Hi,
    Regards,
    Anri.
  • oceansize
    Anri
