Bosch 0280158123 Injector Retaining Clip
    Hello guys,
    just tried to fit Bosch 0280158123 Injectors into S54 Rail, but i can’t use original BMW clips, because the Bosch injectors are little bit longer at the top end and the notch is about 1,5-2 milliliter deeper than on the original S54 injectors.
    Which clips can be used? Any thoughts/Part numbers ?
    what to deal with the extra long nozzle as it can affect negatively on the mixture?
      The S85 uses the same style of injectors and it has 99% the same throttle body and cylinder head design - it shouldn’t be a problem…
