Error codes: 158 and 163 Overspeed?
    Symptoms: I start the car and the idle is rough as hell. I turn off the engine, then restart a few seconds later and the idle is the smooth straight six loveliness.
    So i read the codes. It appears 158 and 163 are due to overspeed. Overspeed of what is the question. Could it be crank revolution speed?
    Code:
    163   internal: Resets Master
    Error frequency : 1
    Logistic counter: 36
       Engine speed                              1520.00  rpm
       relative filling                            16.80  %
       Cooling water temp.                         85.00  degrees C
       Supplier voltage HR                         13.60  V
       aufgetreten vor (rel. BZ)                    2.20  h
       Abort/Function-Time out
       Error not present
       Sporadic error
    158   internal: Resets Slave
    Error frequency : 1
       Error not present
       Sporadic error
    Not about speed;
    it was listed as the status at the moment, just like coolant and voltage.
    code is about master and slave CPU were reset.
