Hey guys, I’ve had BC Racing coilovers on my M3 for about 3 years now (sat most of the time until recently), and am now experiencing a weird hallow noise when going over bumps in the rear. I don’t recall ever hearing it in the past, but now I daily the car and am now questioning if they already need a rebuild.
When to rebuild coilovers?
I had over 50k miles on a set of KW Club sports before they needed a rebuild due to leaking, maxed out settings, and loss of dampening control. I basically drove them into the ground... MCS seem to pride themselves on building better coilovers than most and hopefully they last longer. I doubt I'll experience if that's true or not now that I trailer to and from the track.
Can you recreate the sound if the car is up on jackstands? How do you know it's not the sway bar or rcabs? Good luck
Originally posted by S54330Ci View PostNot sure about BC, however MCS suggests these intervals. I am sure they can be applied to most any high quality coilover.- Street : 25,000 miles
- Street/HPDE: 15-20,000 miles
- Sprint: 150 hours
- Sprint/Enduro: 125 hours
- Endurance Race: 75 hours
- Every 5 years
Originally posted by Wernd View PostI had over 50k miles on a set of KW Club sports before they needed a rebuild due to leaking, maxed out settings, and loss of dampening control. I basically drove them into the ground... MCS seem to pride themselves on building better coilovers than most and hopefully they last longer. I doubt I'll experience if that's true or not now that I trailer to and from the track.
I called TCK directly and they didn't give much merit to rebuilding just based on time passed
They recommended easiest way you can know is to jack up the car, remove the rear lower shock bolt and manually push the shock upwards, if it's slow to return to the original position or doesn't return at all then the seals are shot and time for a rebuild. Other shops have told me this too
Of course a leaking shock means rebuild time as well
Originally posted by usdmej View PostI called TCK directly and they didn't give much merit to rebuilding just based on time passed
FCP Euro warranty
Sent from my SM-S911U1 using Tapatalk
Youtube DIYs and more
