Hey guys, I posted a few things about this in other threads, but I’m officially calling for help now.
Trying to diagnose some exaggerated on throttle clunking after a rear end and subframe refresh. The car is a work in progress and has solid CMP subframe mounts, PowerFlex front differential mount, ECS poly rear differential mounts. Rear wheel bearings are brand new.
I’m checking everything and I have not found anything loose underneath. I have not dropped the exhaust to check the driveshaft center but I know I torqued that stuff. I do have the rear interior removed, which I know contributes to NVH. However, I feel like this sound is maybe not just the poly diff mounts doing the thing they do.
First video is low speed driving around my neighborhood, you can hear the clunking as I go on it off throttle. Second and third videos are showing the amount of play and sounds I can hear when I’m under the car and moving the hubs around. Is this amount of play and these sounds normal? I feel like I might be missing something obvious and I could really use some help!
