Originally posted by Slideways
Let's say you put the diff together and the preload to turn a wheel is too high or low. You have to tighten or loosen the top cap which then changes the carrier preload and backlash. I've found that one full turn keeps you within the backlash spec as long as you started within the .003 to .0035 range. BUT...if you get out of BMWs spec (IIRC .0024 to .0055) then you have to remove the ring gear, reinstall the diff carrier and play with the carrier shims. Doing some math can get you really close on the first try but what a PIA if you're doing it with the case still in the car. If you get the carrier preload correct and change the shims on the side where the top cap is...then backlash should be in spec.
Or just plop in a V1 and call it the day.
