V2 Diff rebuild + Gear Ratio Swap
    Is the locking ring bottomed on this step? If it is then one cannot tighten the ring for preloading the clutch.
    Click image for larger version  Name:	image.png Views:	0 Size:	416.5 KB ID:	297619
    No, it sits slightly higher than the end of the threads. there is a spring washer between the locking ring and the top of the pump, as you tighten the collar it compresses it a bit, so the pump is fully seated in the carrier case.
      "the clutch pack is no thicker than that spacer gear"
      Pic above seems to show the spacer gear is below the top clutch stack shim. No?
      "Now, since I was not able to undo the ring gear, I had to pry on the bearings, dont do this if you are not replacing them, in my case, I am, so it did not matter. It did not take much force, just push gently until you feel it start to move."
      I think one could pry the clutch stack up via the carrier side holes instead on the bearing.
      "The thickess of this gear is what you can use to define the max clutch+steels stack before having preload, per design, there does not seem to be preload."
      If no preload then one can spin one wheel with the other on the ground but this is not the case, and this means clutches are preloaded, and without using a spring washer. Keep in mind the pump movable piston is thicker than the center static part which is pressed on the 'spacer gear' to define the spider gears backlash.
      Yes, but there is some lash, the top spider gear as shown on that photo is line to line on the planetary gears, so that gear and the spacer gear move along the center line of the carrier until the bottom out against the pump
      Yes, but since I still had the ring gear, I was not going to pry against it and mar the teeth.
        Interesting of why they used a spring washer between the pump and lock-ring; why not have the lock-ring directly pressing on the pump? The spring would allow the carrier bearings to float outward, in theory.
        With the pump removed, did you verify that the lock-ring can be turned in passing the locking ball?
          The pump housing (and its static center) is bottomed on the carrier step, this means the space between the 'spacer gear' and the side-gear (the two side-gears and the 4 spider gears are what you called 2 spiders and 4 planetary gears) defines the backlash.
          There is no shim between the pump and the clutches stack? The pic below seems to show the arrowed plate is a shim or spacer as it has no teeth inner or outer. No?
            No shims between the pump and the first steel plate. What you perceive as a shim is the steel plate, you can see the teeth, just cover in oil and clutch material grime.
              I was able to remove the ring gear. All I needed was a larger impact. No issue with the carrier spinning on your hands.
              Click image for larger version  Name:	IMG_1717.jpg Views:	0 Size:	120.4 KB ID:	297698
              I remove all but three bolts and just loosen them to have a few mm of gap to the carrier unit.
              Click image for larger version  Name:	IMG_1719.jpg Views:	0 Size:	115.9 KB ID:	297700
              I then tapped on the edge of the ring gear which is large enough for a flat screw driver, then hammer it out. It does not take much, so the taps can be gentle. Once the ring moves then loosen the bolts a bit more and do another round of taps, then I just remove the bolts and tap until the rings falls off. I put a rag at the bottom of the card box to not smash the ring gear as it falls off
              Click image for larger version  Name:	IMG_1720.jpg Views:	0 Size:	94.6 KB ID:	297699
                It may, but no point in trying it. The pump has to be pressed in until it bottoms out, is a light press fit into the carrier.
                you can see the ring collar and the spring washer below.
                  All new clutch stacks have different thickness due to production process. With a fixed pump and no shim to adjust the clutch preload, I think we’re missing something here.
                    Did you verified the pump housing bottomed out on the carrier or just a guess? It might be bottomed out with a used worn clutch stack, but I don't think it bottomed out with a brand new diff from factory as this would mean impossible to preload the breakaway torque.
                    I believe the clutch stack total thickness must be dimensionally adjusted, with shim if needed, in order to achieve the spec breakaway torque.
                      Continued with the diff work, cleaned all the internals.
                      I found that the spider gears are not in the best shape. Thoughts?
                        Your posted side gear pic looks normal. They turn slowly and only during a turn, so causing low noise. They are not polished as transmission gears which are turning at higher speed and all the time while driving.
                        Foods for thought: V1 has the 4 spiders gears floating as the two shafts are not locked in the holes as compared to V2 with the 2 shafts are in the holes with C-clips.
                        RD removed all side-gears and spiders backlash which causes the infamous clunk noise using the spring washer. The same spring washer only removes backlash on one side-gear and 2 spiders (one the spring washer side), as the other side-gear and 2 spiders are not affected, because the shafts are locked and not floating as V1.
                          C'mon man! Swap that purse for a hammer and whack it! Its hardended steel! lol Seriously, you can whack it if its stuck.
                          Those spider gears look the same as all of the ones I've seen. I think the come with a crap finish from the factory. I wonder if REM polishing would make some kind of improvement.
                            I wonder if REM polishing would make some kind of improvement.​
                            Improve what?
                              Thanks for confirming is normal. Tbh I was expecting a better finish..
                                I measured the V2 kit for GKNV2 unit
                                Steel Plates - 1.03 mm (5)
                                Click image for larger version Name:	IMG_0519.jpg Views:	0 Size:	86.4 KB ID:	263499
                                Thick steel plate: 2.02mm (1)
                                Click image for larger version Name:	IMG_0518.jpg Views:	0 Size:	90.0 KB ID:	263502
                                Clutch plates: 1.1mm (5)
                                Click image for larger version Name:	IMG_0517.jpg Views:	0 Size:	85.0 KB ID:	263500
                                Total stack based on Individual component values - 12.67mm
                                The big spring washer that goes on top of the stack and between the lsd pump is 4.6, and can compress flat to 2mm
                                so total value is ~17.27mm (uncompressed) or 14.67mm (compressed)
                                I also calculated the load the washer needs to compress flat and is 3300N or 320kg (~700#) of force which is meaningful, however without knowing the pump capacity I don’t know if this is much or not; hydraulic pumps have high force capabilities, so if we make an analogy to a car jack, you get the idea.
                                the “free shim” washer needs 2000N to go flat, so I don’t like that much preload for the spider gears. So I will go with flat shims and leave some slack (0.1mm).
                                To document things a bit further. Bellow is the thickness of the OE items, mileage on this diff is unknown.
                                OE Steels are ~.8mm
                                Clutches are ~.9mm
                                As shown in the pictures, the thicknesses are a bit less, so I am assuming the above for new items. so that leaves the stack height at 14.4mm
                                If I were to use all RD items (same number of steels and clutches), this would give a theoretical value of 18mm!!! no way we can fit all of that in the unit. as mentioned above, the clutch pack gear (what I called spacer gear before) has an effective height of 16mm! More than that and you will likely have a lot of preload and risk the first clutch plate to crack by the piston pump, or wont be able to close the unit at all.
                                OE steel plate
                                Click image for larger version  Name:	IMG_1743.jpg Views:	0 Size:	78.9 KB ID:	298176
                                OE clutch plate
                                Click image for larger version  Name:	IMG_1744.jpg Views:	0 Size:	77.0 KB ID:	298177
